Best gas in town?
Starting to re-think my strategy here a bit... My gas tune will essentially be my backup/roadtrip/winter tune - maybe finding and tuning for the best gas available is a bad idea. If I'm roadtrippin I may have to fill up in some small town that has not so great 91 or maybe even 89...
Maybe what I'll do is get my tune dialed in on what I've been using - then try some others and watch the fuel trims & logs to see if there's a difference. If I'm thinking correctly, switching from E10 to non-oxy should run a little rich until the fuel trims adjust for it. No biggy, I'll just have to take it easy if I switch back.
[email protected];326370 wrote:
Maybe I should try non-oxy. I guess I was assuming that the "91 octane" e10 blends would have higher octane than straight 91.Thanks for the suggestions so far. I'm down to about 1/2 tank, another week or so and I'll be ready to try some other options.
Why were you against non-oxy?
PSiedTSi;326372 wrote:
Why were you against non-oxy?My thought process was that the added ethanol would have magical anti-knock properties, but maybe 91 is 91 regardless of makeup... -
[email protected];326373 wrote:
My thought process was that the added ethanol would have magical anti-knock properties, but maybe 91 is 91 regardless of makeup...It might(and sometimes, the ethanol IS the reason it is 91..aka not worth it IMO), BUT, it also has less specific energy and less energy density.
torbs;326365 wrote:
I go to Fleet Farm for two reasons: First, their mid-grade and premium do NOT have ethanol (stock cars, best fuel mileage). Second, they are among the cheapest in town, most often times the same price as Loves and Flying J...Speaking of which, I will NEVER go back to Loves after getting a bad tank last summer. My stock Saturn wouldn't even run on the junk, literally my car would top out @ 25mph until I filled it up with different gas and it would start hard on it.Same reason I go to sams club. Their 87 in ethanol free. I've got around 3-4 MPGs more running pure gas vs stuff laced with ethanol. But the only other option they offer is 89 with 10% ethanol for maybe 3 cents less. But with the membership its either the cheapest or not worth the time and gas to find someone 2 cents less.
I think your logic of building the tune then testing it on other brands should work for what you want. It might not be a scientific test but if all your going to do is use it when you can't find ethanol it doesn't have to be perfect.
Sheeran;326493 wrote:
Same reason I go to sams club. Their 87 in ethanol free. I've got around 3-4 MPGs more running pure gas vs stuff laced with ethanol. But the only other option they offer is 89 with 10% ethanol for maybe 3 cents less. But with the membership its either the cheapest or not worth the time and gas to find someone 2 cents less.I think your logic of building the tune then testing it on other brands should work for what you want. It might not be a scientific test but if all your going to do is use it when you can't find ethanol it doesn't have to be perfect.Thanks, I'll definitely have to try some other fuels once the tune is done. I just sent logs from the 5th tune revision, should be pretty soon. :icon_bounce:
FWIW, I picked up 5 gallons of E85 at Petro Serve by I29 on Main today. Looks like 80% ethanol content according to my tester. I'll probably check a few more spots around town as I go.
Petro Serve/Tesoro on 2nd St: 70% ethanol
Bjornson's on University: 82% ethanol -
Nothing fancy, I use a Quick Fuel Technology Echecker, not really intended to test E10...
http://www.quickfueltechnology.com/specialty-parts/echecker---e85-fuel-test-tube.html
Here's what I had found before I bought the Echecker, it may help. Unfortunately, you'll have to math
Tested the e85 blend from the Petro Serve on 45th St and 9th Ave SW, 74% ethanol.
O how I wish I were a cemistry major and i could do this in the lab with some spare time.
Come to think about it your getting a lot or low ratings on your E-85 so I would assume the same for 10%. Though maybe there dumping more in to save cost and its really like 15% as thats what its going to jump up to in the future.
glad I could help
