  4. Best gas in town?
Best gas in town?
33 Posts 9 Posters 9.2k Views
  • legacy-user-351L
    legacy-user-351L
    legacy-user-351
    Soon! Need to get the gas tune nailed down then we'll be ready to tune for corn. Come to think of it, either way I should start running my tank down to try different gas or to be ready for E85.
    • torbsT
      torbsT
      I go to Fleet Farm for two reasons: First, their mid-grade and premium do NOT have ethanol (stock cars, best fuel mileage). Second, they are among the cheapest in town, most often times the same price as Loves and Flying J...Speaking of which, I will NEVER go back to Loves after getting a bad tank last summer. My stock Saturn wouldn't even run on the junk, literally my car would top out @ 25mph until I filled it up with different gas and it would start hard on it.
      • legacy-user-351L
        legacy-user-351L
        legacy-user-351
        Maybe I should try non-oxy. I guess I was assuming that the "91 octane" e10 blends would have higher octane than straight 91.
        Thanks for the suggestions so far. I'm down to about 1/2 tank, another week or so and I'll be ready to try some other options.
        • legacy-user-351L
          legacy-user-351L
          legacy-user-351
          Starting to re-think my strategy here a bit... My gas tune will essentially be my backup/roadtrip/winter tune - maybe finding and tuning for the best gas available is a bad idea. If I'm roadtrippin I may have to fill up in some small town that has not so great 91 or maybe even 89...
          Maybe what I'll do is get my tune dialed in on what I've been using - then try some others and watch the fuel trims & logs to see if there's a difference. If I'm thinking correctly, switching from E10 to non-oxy should run a little rich until the fuel trims adjust for it. No biggy, I'll just have to take it easy if I switch back.
          • PSiedTSiP
            PSiedTSiP
            Why were you against non-oxy?
            spanish-rice;237125 wrote:
            • legacy-user-351L
              legacy-user-351L
              legacy-user-351
              PSiedTSi;326372 wrote:
              Why were you against non-oxy?My thought process was that the added ethanol would have magical anti-knock properties, but maybe 91 is 91 regardless of makeup...
              • PSiedTSiP
                PSiedTSiP
                It might(and sometimes, the ethanol IS the reason it is 91..aka not worth it IMO), BUT, it also has less specific energy and less energy density.
                • SheeranS
                  SheeranS
                  Sheeran
                  Same reason I go to sams club. Their 87 in ethanol free. I've got around 3-4 MPGs more running pure gas vs stuff laced with ethanol. But the only other option they offer is 89 with 10% ethanol for maybe 3 cents less. But with the membership its either the cheapest or not worth the time and gas to find someone 2 cents less.
                  I think your logic of building the tune then testing it on other brands should work for what you want. It might not be a scientific test but if all your going to do is use it when you can't find ethanol it doesn't have to be perfect.
                  • legacy-user-351L
                    legacy-user-351L
                    legacy-user-351
                    I think your logic of building the tune then testing it on other brands should work for what you want. It might not be a scientific test but if all your going to do is use it when you can't find ethanol it doesn't have to be perfect.Thanks, I'll definitely have to try some other fuels once the tune is done. I just sent logs from the 5th tune revision, should be pretty soon. :icon_bounce:
                    • wishinskyW
                      wishinskyW
                      wishinsky
                      I use bjorhnson's by Sunmart and autozone on I believe uni and 6th super unleaded 90 for $3.5
                      -Cars i drive
                      2002 Mustang
                      1997 Bravada Smart Track
                      • Toys
                        05 TTR 125 L/LE
                        02 YZ 85 with 110cc kit
                      • PSiedTSiP
                        PSiedTSiP
                        How relevant. Cool story, bro.
                        • wishinskyW
                          wishinskyW
                          wishinsky
                          😉 glad I could help
                          -Cars i drive
                          2002 Mustang
                          • Toys
                            05 TTR 125 L/LE
                          • legacy-user-351L
                            legacy-user-351L
                            legacy-user-351
                            FWIW, I picked up 5 gallons of E85 at Petro Serve by I29 on Main today. Looks like 80% ethanol content according to my tester. I'll probably check a few more spots around town as I go.
                            • legacy-user-351L
                              legacy-user-351L
                              legacy-user-351
                              Petro Serve/Tesoro on 2nd St: 70% ethanol
                              Bjornson's on University: 82% ethanol
                              • S
                                S
                                Specialis
                                • S
                                  S
                                  Specialis
                                  • legacy-user-351L
                                    legacy-user-351L
                                    legacy-user-351
                                    • SheeranS
                                      SheeranS
                                      Sheeran
                                      WHat is your tester? I'd like to go test some of the 87 with up to 10% ethanol to see who has the least content so my turd box can get top mileage.
                                      BTW If you havn't noticed sams club is now 10% ethanol 87 and 10% ethanol 91.
                                      • legacy-user-351L
                                        legacy-user-351L
                                        legacy-user-351
                                        Nothing fancy, I use a Quick Fuel Technology Echecker, not really intended to test E10...
                                        http://www.quickfueltechnology.com/specialty-parts/echecker---e85-fuel-test-tube.html
                                        • SheeranS
                                          SheeranS
                                          Sheeran
                                          wow thats pretty cheap. I see what your saying though, I will pick one up if I have a car that runs E-85 ever.
