  3. ICE and Detailing
  4. First Thread.
First Thread.
38 Posts 22 Posters 10.5k Views
    Read what it says in my previous post. "cheap and gets the job done" never said to use it in your award-winning evo or sti. it worked on the galant, and it never messed anything up. (that I noticed)
      mulitpurpose expanding foam is the worst product on the market today. I hope you didnt ruin anything by using it.
        wannabe wrote:
        multipurpose expanding foam. cheap and gets the job done.
        damn ricer! i was into the car systems for awhile, but then now all i want is some nice componants and a good cd player and that will do me just fine.
          I have to agree, expanding foam is not a very good thing to use for sound deadening and can wreak havoc on any panel you spray it behind. Stick to the tried and true methods joel.
          • treimcheT Offline
            treimcheT Offline
            treimche
            I used to have a huge stereo in my old Oldsmobile back in high school. Then I transferred it to my 1G DSM when I had that. Since then haven't bothered much with it because my car is a huge bitch too, so when I get a truck or nice dd, then I'll consider some stereo again.
            Troy
            2009 Yamaha R1
            2002 WRX
            2001 Toyota Tundra
            2001 Yamaha R6
            1988 Yamaha YSR 50
            2003 XR50
              It is not a very good product to use on anything for that matter.
              • LT1L Offline
                LT1L Offline
                LT1
                i love bumps, music aint the same w/out it
                  TRE
                  Expanding foam=no good
                    no lie
                    • My NOvaM Offline
                      My NOvaM Offline
                      My NOva
                      expanding foam does not work at all for sound dending unless its a full room and ur sealing the corners
                      Hey Tina come get some hamm
                        actually, it kinda does work by applying pressure to a panel to keep it from rattling. But just spreading it on does nothing.
                          ...and you should be careful what it is you are applying it to. it has been known to break windows, door frames, and even heave foundations.
                            well sound only matters from the inside right forget the foam and jsut enjoy the musics....and a few bumps never hurts nothing
                            • My NOvaM Offline
                              My NOvaM Offline
                              My NOva
                              my point exactly
                                While this is technically true that it only matters on the inside there is a huge advantage to reducing rattles since harmonics caused by rattles can in fact cancel out frequencies that you want to have playing. In fact, by applying dynamat or any other sound deadener (Roadkill, brownbread, Cascade, etc....) you can effectively quiet the interior to the point where it would be the rough equivalent of doubling your amplifier power. Its not uncommon to gain 3 decibels of sound pressure by stopping rattles...and 3 decibels is the same as doubling your amplifier power. Just to clarify, that does not mean it is twice as loud. You need to get 10 times the amplifier output (on the same number of speakers) to get twice as loud (10 decibels). In other words if you make 90dB at one watt w/ 2 watts of power you will only make 93 dB; w/ 10 watts you will make 100dB, w/ 100 watts you will make 110 dB; and w/ 1000 watts you will make 120 dB (and this is only in a perfect environment, usually you make less of a difference by going up in power by 10 times the normal amount...say 7-8dB for every time you increase power 10 times)
                                • HoboKameraH Offline
                                  HoboKameraH Offline
                                  HoboKamera
                                  amicheze wrote:
                                  i had a pretty decent system in my old car. nothing too fancy, but it pounded pretty well in an old grandmamobile. i kinda wish i still had it.. or at least the money for it.. cough
                                  i gave you a $300 deck and more then $300 in speakers for free... 😕
                                  '05 Neon
                                    BlueSPI02
                                    i like my sound system bc i know my car isnt fast at least i have a car so thats all i really care about
                                    Cross into the Blue
                                      ^^^^^nova, can we get a translation?^^^^^
