  3. Track Talk
  4. Racing on memorial day.....
127 Posts 40 Posters 13.7k Views
    So the best I was able to muster out of the GSX this weekend was a 15.1. Anytime I tried to launch hard the clutch would spin. So I had to launch at like 2500-3000 rpms. Consequently my BEST 60' of the day was a 2.27, and that was my 15.1@92. With a different clutch I should be able to easily shave off .5-1.0, but I don't think we'll ever know.
      Blake, I FEEL YOUR PAIN! I'm not going to say anymore. those that were there know what I'm talking about.
      • DaveHD Offline
        DaveHD Offline
        DaveH
        heh, well I guess 29.5x10.5 is small compared to what some people run. 😛 I can't get anything bigger than a 28 under my wheel well.
        The track was sticky at first, but it deteriorated quite badly. You car would prob lift the wheels and hook on a gravel road. LOL I know my car would just spin, and Ethan said that he lost all hope of launching his bike well after a hour or two. What is your weight bias front/rear? I noticed that you had ladder bars on there, why not 4-link? (obviously the ladder bar works I guess). The odd thing is that my car had no traction issues other than right on the starting line. I saw that you got loose in the middle on the one pass, my car just drove down the track with no issues. I wasnt spraying so my 1/8 mile mph was only 103-105.
        homer wrote:
        I had the small tires on it (29.5x10.5x15), actually thought the starting line was better Monday night than on Sat/Sun, since track temp was finally decent and there was less humidity in the air & I increased air pressure 1 lb to 8.5 lbs, since had too much wrinkle and was folding tires over when launching.
        The LC6 held up nicely and track actually has too much rubber on it right now & needs to be scrapped. Alot of sand/dirt was on track from cars parking in the dirt/mud than making runs, but that was the fun part for me, seeing if we could stay in the groove & drive through it, (First pass obviously I didn't and peddled it a couple of times to drive back into it) & the groove was tight and their wasn't much room for error.
        **First **pass was a 10.21 @ 133.47, 2nd pass I didn't get a correct time but with Data Logger info and short times was a high nine leaving soft probobly at the same MPH. 3rd pass was decent up to 660' (9.78 @ 140mph) but car nosed over after that and we just missed the tune and are running too lean with the alcohol with 172 jets & I don't think the 4:88 gears are helping like we thought.
        Didn't change suspension, just tire pressure, since only have ladder bar/coil over system and only changes to shock settings and spring rate that I can make will only help on rough tracks.
        Hopefully we get it figured out since car is now slower than it was $7K ago & I am still slower than 2Wheeler :mad:
        PS:
        May 30, 2005
        07:47:40 PM
        2356 DA
        **71.7 Degrees F **
        45.8% Humidity
        57.5 Degrees F Dp
        0.47 Vp
        0.925 ADR
        DaveH
        '94 Supra- 7.77 @ 176mph
          pin
          PSiedTSi wrote:
          were you running slicks?
          Yes, hence the mention of slicks in my post.
          Barry
            oh i didnt even realize that at the track...i assumed that by your post but i wasnt sure...
            • LT1L Offline
              LT1L Offline
              LT1
                pin
                caption for the last picture - "Thanks for topping off my radiator, harwood."
                Barry
                • PhatsP Offline
                  PhatsP Offline
                  Phats
                  STiSchucky wrote:
                  hmm. i have a boost controller set at 16 psi, headers and turbo back exhaust...maybe once he gets those, he'll be up there with me in the low low 13s.
                  Yeah that's what he's waiting for......he was pretty frustrated 'cause he saw you running low 13's so he thought he should be right there. He's a good friend of mine, and since i've been through the all-wheel-drive woes, and figuring out the launches, i was trying to help him best i could.
                  02 GSXR-1000
                  97 540i
                    HandoEX wrote:
                    Maybe try some weight reduction 😉 😉 😉
                    or maybe he could put a 350z motor in it and run faster then the Z its self
                    • F Offline
                      F Offline
                      fanaticrockford
                      I'm trying
                      • F Offline
                        F Offline
                        fanaticrockford
                        Ok Smart ass i know a rwd motor will not fit in a fwd. I could use the same 3.5 platform though.
                        The fastest 3.5 NA 350z i have seen ran a 13.1
                        The fastest 3.5 NA Altima i have seen ran a mid 13 (unsure though)
                        The fastest 95-99 3.5 Swap NA Maxima runs a 13.3
                        The fastest 02-03 3.5 NA Maxima ran a 12.8
                        Thers the proof. Most 350z's run low 14's and some high 13's
                        • XJHEADX Offline
                          XJHEADX Offline
                          XJHEAD
                          camzaro28 wrote:
                          fargo what happend to ur car? guess it wasnt anything bad
                          They saw a drop of oil on the ground coming out of the b/out box :rolleyes: :rolleyes:
                          7.64 @ 187 3400 lbs. on KORN
                          TTSBF
                          RTCTTFMF PTOSITW
                            heh, him and the white sti were runnin similar times. Is your buddy even on this site?
                            • bluejaysB Offline
                              bluejaysB Offline
                              bluejays
                              i know the guy, he is on the tintmaster site. he is not on this site though. i told him about it though.
                              • DaveHD Offline
                                DaveHD Offline
                                DaveH
                                Does anyone have pics/vids from Memorial Day? I was usually messing with my car so I didn't get much of a chance to watch.
                                DaveH
                                  I don't get your point? "Most" Maxima's prob run 15's or 16's......
                                  • homerH Offline
                                    homerH Offline
                                    homer
                                    They saw a drop of oil on the ground coming out of the b/out box :eek:
                                    Ford guys, you'd think with the amount of horsepower they build & as smart as they are, they would either:
                                    1. Have an engine that didn't blow the dipstick tube out
                                    or
                                    1. Follow the rule book and have a positive lock oil & trans dipstick tube
                                    Sorry Bill, Couldn't resist.........................
                                    "Will Work for Food"
                                      i have a vid of monday and will be getting it online by next week
                                      • DaveHD Offline
                                        DaveHD Offline
                                        DaveH
                                        Homer, whats up with selling your fast car and all the stuff with it?
                                        Dave
                                        homer wrote:
                                        :eek:
                                        or
                                        DaveH
                                        • homerH Offline
                                          homerH Offline
                                          homer
                                          I think I am going to take up Fishing & Buy a "Hot Rod" Ford Focus :rolleyes:
                                          or maybe start fixing up my Funny Car :eek:
