  4. Boost controlling
Boost controlling
27 Posts 7 Posters 2.9k Views
    Size wise the tial's are usually smaller than the turbonetics wastegates actually.
      TRE
      sounds like a plan, they have a 17.4 psi spring so I think i will go with that, they also have a 18.84 psi spring.... My fuel is set for 18psi but then i am going to fine tune just a bit, witch spring should i go with?
        TRE
        One more thing what is this thing about wastegate creep or whatever it is called, do i need to worry about that? Worry about my wastegate not allowing my turbo to spool as fast or is that more for non external wastegated turbo set ups?
        • 91nbtsi9 Offline
          91nbtsi9 Offline
          91nbtsi
          Go with the Tial 38mm with the 18.xx spring. What are you putting this on? You mentioned a 1.3l engine, you will not have to worry about creep with a 38mm gate at ~18psi. This would be a perfect setup for you.
          [email protected] -- DSM
          07 Mega Cab 5.9 CTD
            TRE
            better to go with higher boost than lower boost?
            • 91nbtsi9 Offline
              91nbtsi9 Offline
              91nbtsi
              Haha, duh! No, depends on what you are turboing, what turbo, etc. Lets hear some details. But definately a tial is the way to go.
              07 Mega Cab 5.9 CTD
                A TIAL 38mm is plenty big for the turbo you plan on using.
