  4. Plane on a conveyor belt
298 Posts 57 Posters 14.6k Views
  • StormwalkerS Offline
    Stormwalker
    Dubbsy, you weren't supposed to post in this thread! Since people have begun linking to other threads already, I'll throw in my link (scotwithonet actually described the situation a lot better than people on other boards):
    http://www.tcstangs.com/forum/showthread.php?t=26984
    www.tcstangs.com
    • dubbsyD Offline
      dubbsyD Offline
      dubbsy
      Sweet-WRX-Lovin wrote:
      The plane will take off. The conveyor will keep matching the wheels speed but the plane itself will continue to move forward in space due to it's propulsion being independent of the restrictions imposed by the conveyor.
      actuall that is partiall incorrect..
      the conveyor will not match the wheel speed.. the wheel speed is the combined speed of the conveyor and the plane.
      1995 Mustang
      CAI, rimz, and springs.
        Stormwalker
        Here is another interesting link:
        http://www.avweb.com/news/columns/191034-1.html
        www.tcstangs.com
        • Ashli19A Offline
          Ashli19A Offline
          Ashli19
          The plane will take off because the wheels are entirely independent from the plane's engines. The engines on the plane create thrust=displacement of air. The engines draw air under the wings more quickly then they pull air over the tops (der thats a given) so if the plane's engines can generate enough lift, even though the wheels are spinning a bajillion miles an hour, it will take off. The plane doesnt have to physcially move to take off, it just has to move enough air under its wings. Think about the reasons cars have diffusers under them. If the car is moving too fast (AIR IS MOVING TOO QUICKLY NOT THE ACTUAL CAR) it will generate lift and lose control.
          -mitch
          edit/ I just realized that is pretty much what sweetwrxlovin just said
            OK, so I went to the mythbusters site and was going to post this as an idea and come to find it's already on there in the discussion forum. It seems there is a video out there that proves that the plane WILL take off. So, if any of you are up to the task of finding it you're welcome to it, it's too late for me to search now but I might get a notion to tomorrow.
            • dubbsyD Offline
              dubbsyD Offline
              dubbsy
              -mitch
              Mitch, if I"m reading this right...everything about it is wrong...
              #1. Air travels faster over the tops of wings.. This creates a low pressure that in turns sucks the wing up (bring the plane up with it)
              #2. The plane DOES have to physically move. The engines do not move enough air around the plane to create lift. ...but no matter what, when thrust is applied, the plane will move in relative space and the plane will take off just like there was no conveyor there in the first place.
              1995 Mustang
                maybe im just physics retarded (never did take the class) but i still dont see how the plane can take off. since the plane needs air to flow over its wings to take off - and since the conveyor exactly matches the plane speed (to me, meaning the plane doesnt move forward at all) - it cant take off.
                • Sweet-WRX-LovinS Offline
                  Sweet-WRX-Lovin
                  Right. It can't as the plane accelerates. Just tried the simple answer.
                  Amicheze, the planes way of moving forward, thrust from the engines, is totally independent and free from the coveyor moving and the wheels. The wheels end up acting like bearings (which they are I guess) and the more the conveyor trys to hold the plane in one place while it moves forward, the faster the wheels will spin and that's it. The plane itself will just continue to accelerate forward while the wheels and coveyor just keep spinning faster and faster.
                  In other words the conveyor and wheels don't exist and it's just the thrust of the engines moving the plane forward.
                  One time...
                  • lord_deastofactL Offline
                    lord_deastofact
                    well I thought about this one through and through debated it with my roommate and I descovered the crux of the issue, there are two schools of thought that will clash on this. the free thinkers and those who are bound to constraints. if you don't think outside the box, the plane will never take off. but since I don't think like that I came to the solution rather quickly. negating the obvious errors in the queston and assuming that by saying plane they ment airplane not aircarft and most certianly not just a "plane".
                    the solution I arived at is that since the question did not set any limitations on the craft, at a certian point the airplane would achieve an amount of pounds thrust that is greater then the mass of the aircraft. in essense turning the craft into a rocket and negating the need for wings at all. it will move simply by newtons laws of motion. and at such a point the only way to stop it from moving is to increase it's mass to something greater then what the engine is capable of producing thrust to compensate for. but no matter what with the right amount of thrust the craft will move no matter what. even if you tie it to the earth. with a amount of thrust that is totally unrealistic of achieving it would move the earth as well and become yet another spacial object.
                    but this is only taking into account that you do not limit the solution to restraints that the question never stated. this is how advances are made in science by forgetting about past flaws, if people didn't think like this, the earth would still be flat, the sun would revolve around us and apples wouldn't fall.
                    Minute ricer!
                      ok. here is my line of thought..
                      let plane speed = A
                      let conveyor speed = -A (since theyre exact opposites of each other)
                      A + -A = 0 meaning no forward movement.
                      no forward movement = no flow over/under the wings = no lift
                      i understand your thoughts about how the plane's wheels will just keep spinning.. but arent the wheels attached to the plane? if so, if all the wheels are doing is spinning, how is the plane moving forward? to me it would be like trying to run on a treadmill. if its moving the same speed as youre running, your head wont go anywhere even though your legs are trying to move you forward.
                      • 51d3w4yz5 Offline
                        51d3w4yz5 Offline
                        51d3w4yz
                        That is because your legs are your source of propulsion on the treadmill, for the airplane, it is the engines pushing air and the wheels have nothing to do with it. How do Ski/float planes take off without wheels, because they aren't necessary so it doesn't matter how the wheels are moving, the plane is pushing forward with air.
                          Sweet-WRX-Lovin
                          It's a little different than that, in my opinion I guess. What you are assuming is that the planes ability to move forward is directly tied to the wheels (it is not I'm assuming in this situation). Let's use the treadmill analogy. You put a skateboard on a moving treadmill. If the wheel bearings of the skateboard are perfectly frictionless (like what I'm assuming with the plane's wheels here), the skateboard itself will not move. The wheels will spin with the treadmill, but the skateboard itself will not move. Now we have the wheels vs conveyor thing illustrated. They negate each other. The only force left acting on the plane is the thrust of the engines. This is the only force left (magically of course). Since it is the only force left, the plane moves forward and takes off.
                          One time...
                            yeah the plane's jets are pushing it forward.. but gravity is holding the plane down onto the belt. since the wheels are actually what are touching the belt.. theyre just going to spin. ski/float planes dont take off of something moving the same speed in the opposite direction.
                            im trying to understand.. but my common sense (at 3 in the morning) says it cant happen.
                            edit: written before the above post. i think i got it.
                              Sweet-WRX-Lovin
                              That's a big 10-4 on the 3 in the morning biz. If I hadn't slept all day cuz I was working all night last night I'd be in bed so long ago. The gravity holding the plane down on the belt as a way of holding it from moving horizontally is negated by the magic of the ever popular assumed frictionless bearings. Lots of assumptions and whatever in all this bizness, interesting question Chuck 🙂
                              One time...
                              • dubbsyD Offline
                                dubbsyD Offline
                                dubbsy
                                Tjamz has a great analogy for this but I'll let him post when he gets bored and sick of watching you all hash it out. 🙂
                                oh, BTW. the plane will take off.
                                1995 Mustang
                                • 2wheeler2 Offline
                                  2wheeler2 Offline
                                  2wheeler
                                  ok, heres my take....you need the airflow above and below the wings to make the plane leave the ground. If you've ever run on a treadmill, you'll know that you get hot because no matter how fast you run, there is no airflow going over your body. If you run around a track or outside or something, the airflow will cool your body.
                                  With no airflow, the plane stays on the ground.
                                  '08 Suzuki Hayabusa
                                  '09 Yamaha Zuma 200cc
                                  '95 E-350 7.5L
                                  • bluejaysB Offline
                                    bluejaysB Offline
                                    bluejays
                                    in a perfect world with no friction or delay it wouldn't, but since the control system has to tune the speed it won't be instantaneous, which will allow the plane to start moving before the machine can actually "tune" the speed.
                                    • PhatsP Offline
                                      PhatsP Offline
                                      Phats
                                      So, Dubbsy
                                      Explain too me why the foreword thrust wouldn't move the tires more.
                                      Plane has thrust on it's body, pushing the plane a 50mph, the wheels, attached to the plane, spin at 50. The "Treadmill" spins at 50.
                                      The plane has thrust pusing it's body too 100mph, that means the plane needs too acelerate, forewords, because we need too go forwords to generate lift, we all know that.
                                      so, if the plane goes forword, the wheels turn forword, the Treadmill matches the wheels.
                                      Which means it matches the plane.
                                      Which means that it doesn't matter what speed the Jets are pushing the plane, the wheels are going that fast too, and as long as they are, the treadmill is matching.
                                      I understand what u are saying, but, it's not possible too me.
                                      If u can explain it, please do.
                                      02 GSXR-1000
                                      97 540i
                                      • PhatsP Offline
                                        PhatsP Offline
                                        Phats
                                        For the plane to move forword, the wheels must move forword, which means the tradmill moves the other way.
                                        Unless u can kill my theory.
                                        02 GSXR-1000
                                        97 540i
                                        • bluejaysB Offline
                                          bluejaysB Offline
                                          bluejays
                                          Phats wrote:
                                          So, Dubbsy
                                          that is what i was thinking, but that is in a perfect world.
