  4. I need help
I need help
16 Posts 9 Posters 707 Views
    91nbtsi wrote:
    You just need a bigger prybar:icon_cyclops_ani:
    Thanks for the advice Nate... I got them out using very large flathead screwdriver.
    The motor is now officially out... 4 hours for my first ever engine removal(the right way)... I didn't think it was too bad. Now comes the fun part of getting the y8 in and running. Should be done by this weekend if it doesn't rain too much. I'm doing this in my driveway since my parents dont want it in the garage...
    I'm debating whether or not to take the time to take the tranny off and look at the clutch before it goes back in... I will be needing one pretty soon anyways, but since the motor is out I thought it might be easier right now.
    • NickBN Offline
      NickBN Offline
      NickB
      Do the clutch while its all apart
        ^^^makes alot of sence...
          yes, to doing the clutch now. it well make thing easier in the long run, that is why i am doing everything while i had the motor out
            psh, don't bother doing a clutch! 😄
            clutches are gaysauce. You should weld the input shaft right to the flywheel.
                      haha, I think the admin owned this thread. 😄
                      • BlueSRT0483B Offline
                        BlueSRT0483
                        Ya and technically your car would be a hybrid if you went that way..
                        Run out of gas, just turn the key forward in the starting position and steer away, let's hope your near a gas station :icon_salut:
                        2004 Dodge SRT-4
                        ...Formerly "A853"...
