  4. Injectors.
Injectors.
9 Posts 6 Posters 525 Views
  • M Offline
    M Offline
    moparguy
    If one were to try to find a set of fuel injectors that would flow around 46 lbs/ hr, where would one find a good price on oh say....8 of them? that would also be a high quality peice that would last for quite some time.
    and does anybody know anybody else with access to a TIG welder that knows aluminum?
      The answer to both is Nick at SLS. PSI2HI on here. He be the man with a tig.
      • M Offline
        M Offline
        moparguy
        Thanks. I'll have to call Nick or ask him next time he swings by the shop.
        • ticklemedalyT Offline
          ticklemedaly
          Either him, or check out some RC Engineering injectors. Go to there site, or some site that sells them. Find your application, and they will list flow rates. High quality, decent price.
          Ry
          XBL G-tag: TickleMeDaly83
          • M Offline
            M Offline
            moparguy
            nobody will carry injectors for my application. Not too much call for injectors for a built up 440 mopar.
              gonna maybe have to get a custom fuel rail to run like DSM injectors etc...
                Won't you need a standard domestic style injector? I have a import style and a domestic style injector laying around you can use to test fit if you want. You'll need high impedance I'd guess? RC is very expensive for what you get, and they use the same injector as everyone else (IMO).
                • D Offline
                  D Offline
                  dynotune
                  I can get you bosch style 48s (high imp, 12-14 ohm) pretty reasonable (accel) RCs are kind of finicky sometimes depending on what you use them in.
                  DynoTune Speed & Performance
                  Mobile chassis dyno service
                  www.dynotuneusa.com
                  (605) 753-1101
                  • D Offline
                    D Offline
                    dynotune
                    you can get svo green tops for less than $300 as well... (42s)
                    www.dynotuneusa.com
                    (605) 753-1101
