  4. big boost problem!!!
13 Posts 5 Posters 959 Views
  • GnArKiLlG Offline
    GnArKiLlG Offline
    GnArKiLl
    i have been having this issue with my laser for a while but when i get on the gas it will build boost but the car just boggs and if i get of the gas and right back on it will be just fine i just need to figure this out...
    1976 Chevy K5- lifted beater
    • JohnWJ Offline
      JohnWJ Offline
      JohnW
      check for boost leaks first. also are you sure it's actually building boost, i mean do you have a boost gauge (stupid question but just making sure)? if you have a data logger, check your timing retard and knock. i had the same problem with my previous turbo. the oil seals were blown and it had mega shaft play. a new turbo solved my problem.. just some ideas on what to check. im no dsm guru tho. check dsmtuners.com also, lots of info there.
      90 Civic DX hatch
      D16a6/y8 mini me
        i think you might need to check your boost fluid :icon_thumright: :icon_thumleft:
        but on a more serious note check the turbo condition
        • GnArKiLlG Offline
          GnArKiLlG Offline
          GnArKiLl
          no shaft play and yes i have a gauge im set at 15psi
          • darkelvisD Offline
            darkelvisD Offline
            darkelvis
            sounds like you have a case of dsmotitis. Seriously though, check your ignition system, your injectors, and check for boost leaks.
            • GnArKiLlG Offline
              GnArKiLlG Offline
              GnArKiLl
              how do i check for leaks
                my car kinda does the same...but just studders a little bit...only cuz it runs so damn rich cuz my o2 and mas are bad.
                • GnArKiLlG Offline
                  GnArKiLlG Offline
                  GnArKiLl
                  i mean if i rev it up and dump the clutch like im racing it never does it
                  • JohnWJ Offline
                    JohnWJ Offline
                    JohnW
                    definately get yourself a logger or find someone who has one that you could use. check your o2 voltages to see if the o2 sensor is working properly, and check for knock, and check your timing advance at low rpm. check your ignition too, see if you can borrow someone elses ignition coil to see if that helps any. check your alternator voltage and check for fluctuations which could mean a bad ground. seriously tho dsmitis is right, there are so many things which could cause the symptoms you are getting. its just a matter of getting all of the information you can (data logger, boost leak tester, etc.) and narrowing the problem down bit by bit. you need to check out dsmtuners.com if you haven't and search the newbie forums. there is so much usefull information there it's silly. this may not be something you will be able to diagnose and fix lickety split, so resign yourself to working at it until the problem is solved. DSMs are great eh?
                    90 Civic DX hatch
                    D16a6/y8 mini me
                    • GnArKiLlG Offline
                      GnArKiLlG Offline
                      GnArKiLl
                      thanx guys this just sux cuz i cant find any parts for a 90!!
                      • JohnWJ Offline
                        JohnWJ Offline
                        JohnW
                        http://www.mitsubishigraveyard.com/
                        if you don't see it, call. chances are, they have it 🙂
                        90 Civic DX hatch
                        D16a6/y8 mini me
                        • GnArKiLlG Offline
                          GnArKiLlG Offline
                          GnArKiLl
                          ok i wired in a 91+ coil,tansister and gauge cluster also a 91+ ecu( i have a 90) it made the boost problem stop for a bit but my tach still dont work i did everthing this site http://www.ecanfix.com/users/mdhamilton/ecuconversion.html had to say sombody plz help
                          • JohnWJ Offline
                            JohnWJ Offline
                            JohnW
                            hrm, i dunno past the suggestions i've already fielded. try posting on the newbie section of dsmtuners.com, someone there is bound to know.
                            90 Civic DX hatch
                            D16a6/y8 mini me
