  2. Introductions
  3. Introductions
  4. My car and I
My car and I
27 Posts 18 Posters 1.6k Views
    That is titties.
      Welcome to Fargostreet!
      • smtomps1955S Offline
        smtomps1955
        welcome to the boards!
        2003 f150 supercrew
        2002 Urabus WRX sedan
        1991 Nissan Hardbody
        :icon_puke_l:
        • Meat WagonM Offline
          Meat WagonM Offline
          Meat Wagon
          97jeep wrote:
          mods?
          Benson Sleeved 84mm b18C5
          B20 Crank
          CP Pistons
          Manley Rods
          ITR Cams
          VictorX Intake Mani
          MSD Pro Billet Distributor
          Ramhorn Mani
          t3 T67
          Big Intercooler
          Tial BOV
          Tial 38mm wastegate
          3in downpipe with 3in exhaust
          Bosch External Fuel Pump
          All steel braided fuel lines
          Hondata s300
          Runs on E85 fuel
          b16 trans
          itr diff
          RPS clutch
          ITR 5 lug
          M&H 235/60/15 DOT's
          It made 472whp and 360tq on a dyno dynanmics machine on 24psi. Dyno dynamics dyno's read lower than most. Its comes out to about 527whp on a dynojet. This was on E85 fuel. Would have tuned on more than 24psi but the greddy Profec type S wouldn't go any higher on the 10lb wastegate spring.
            nice! nobody from bismarck ever shows their face, its hard to tell if theres any life over there...never really seen any cars from there
              Meat WagonM Offline
              Meat Wagon
              There is no life over here. I can't find any thing to race. Once i get new axles i will be traveling for some action.
                Not to change the thread but do you ever see a blue 1Gb Talon AWD with FMIC, 50 trim etc running around? I heard it was broken awhile ago but I want to find the guy that owns it because I kinda want it back haha...
                • ErikE Offline
                  ErikE Offline
                  Erik
                  That's a crazy setup! Big props for running e85!!
                  They call me, old man...
                    Hi Corey. waves
                      Thats cuz they all see your FMIC from two miles away and RUN! Nice car, nice setup!
                      • 91nbtsi9 Offline
                        91nbtsi9 Offline
                        Sweet car! You need to come up to Interstate so we can watch you spin out;) (on the street nights anyways)
                          Mmmm 5 lug! Nice civic, more pictures please.
                            Meat WagonM Offline
                            Meat Wagon
                            I prefer to keep it on the streets.:D
                              aliengotpsi
                              pussy........
                              Kevin Smith
                              Straightlinedetailing.com
                                Meat WagonM Offline
                                Meat Wagon
                                aliengotpsi wrote:
                                pussy........
                                hahahha 🙂
                                • ticklemedalyT Offline
                                  ticklemedaly
                                  wouldn't you pull more power with regular 93 or higher unleaded octane? or just adding a little racing fuel to the tank too? I believe E85 has lower power figures and worse gas mileage.
                                  Ry
                                  XBL G-tag: TickleMeDaly83
                                    It doesnt have low power figures you just need to run a little more rich than usual...people are converting their cars to it and having decent results because they can run an overhaul higher boost map...
                                      Meat WagonM Offline
                                      Meat Wagon
                                      Ry
                                      Sorry, but you're wrong. If you want to compare octane ratings, e85 is rated at 105 octane. I'm paying $2.49 a gallon right now for e85. I beleive c16 is around $9-10 a gallon. You do need to run more ethanol to equal the same amount of gas. Anywhere from 20-50% more fuel. I get about 22mpg on e85. The best part of e85 is that it burns cool. Last week on an 80 degree day my intake temp was 94 degrees. After some spirited driving the intake manifold is room temperature to the touch.
                                      • 91nbtsi9 Offline
                                        91nbtsi9 Offline
                                        What does your fuel burning cool have to do with your intake temps? Aside from the small amount of heat transfer that will occur from your head to your intake during operation and any reversion... Intake temps are dependent on the efficiency of your turbo, IC, and the temp of the intake into the turbo.
                                        Anyways though, E85 is higher octane and does have good potential. But, like you say, you need more of it; about 1.5times as much IIRC.
                                        Now, E85 does burn cooler, but your intake temps aren't a direct result of this unless you are maybe sucking in exhaust gasses?? Your combustion and exhaust temps should be lower, which allows wilder tuning:icon_thumleft:
                                        I should get some bigger injectors and run the Yota on E85...:icon_scratch:
                                        • 3_Series3 Offline
                                          3_Series3 Offline
                                          3_Series
                                          E85 has about a 25-30% disparity in mileage compared to gasoline. Car and Driver tested a flex-fuel Tahoe with both fuels and consistently achieved higher mileage with 87 oct (E85 reduced driving range by about 100 miles). Albeit E85 did have slightly better performance, but the figures are insignificant at best.
                                          2002 Subaru Legacy
                                          1993 BMW 325i (sold)
