  2. Introductions
  3. Introductions
  4. My car and I
My car and I
27 Posts 18 Posters 1.6k Views
    Meat Wagon wrote:
    I can't find any thing to race.
    Thats cuz they all see your FMIC from two miles away and RUN! Nice car, nice setup!
    • 91nbtsi9 Offline
      91nbtsi9 Offline
      Sweet car! You need to come up to Interstate so we can watch you spin out;) (on the street nights anyways)
        Mmmm 5 lug! Nice civic, more pictures please.
        • Meat WagonM Offline
          Meat WagonM Offline
          Meat Wagon
          I prefer to keep it on the streets.:D
            aliengotpsi
            pussy........
            Kevin Smith
            Straightlinedetailing.com
              Meat WagonM Offline
              Meat Wagon
              aliengotpsi wrote:
              pussy........
              hahahha 🙂
              • ticklemedalyT Offline
                ticklemedaly
                wouldn't you pull more power with regular 93 or higher unleaded octane? or just adding a little racing fuel to the tank too? I believe E85 has lower power figures and worse gas mileage.
                Ry
                XBL G-tag: TickleMeDaly83
                  It doesnt have low power figures you just need to run a little more rich than usual...people are converting their cars to it and having decent results because they can run an overhaul higher boost map...
                    Meat WagonM Offline
                    Meat Wagon
                    Ry
                    Sorry, but you're wrong. If you want to compare octane ratings, e85 is rated at 105 octane. I'm paying $2.49 a gallon right now for e85. I beleive c16 is around $9-10 a gallon. You do need to run more ethanol to equal the same amount of gas. Anywhere from 20-50% more fuel. I get about 22mpg on e85. The best part of e85 is that it burns cool. Last week on an 80 degree day my intake temp was 94 degrees. After some spirited driving the intake manifold is room temperature to the touch.
                    • 91nbtsi9 Offline
                      91nbtsi9 Offline
                      What does your fuel burning cool have to do with your intake temps? Aside from the small amount of heat transfer that will occur from your head to your intake during operation and any reversion... Intake temps are dependent on the efficiency of your turbo, IC, and the temp of the intake into the turbo.
                      Anyways though, E85 is higher octane and does have good potential. But, like you say, you need more of it; about 1.5times as much IIRC.
                      Now, E85 does burn cooler, but your intake temps aren't a direct result of this unless you are maybe sucking in exhaust gasses?? Your combustion and exhaust temps should be lower, which allows wilder tuning:icon_thumleft:
                      I should get some bigger injectors and run the Yota on E85...:icon_scratch:
                      • 3_Series3 Offline
                        3_Series3 Offline
                        3_Series
                        E85 has about a 25-30% disparity in mileage compared to gasoline. Car and Driver tested a flex-fuel Tahoe with both fuels and consistently achieved higher mileage with 87 oct (E85 reduced driving range by about 100 miles). Albeit E85 did have slightly better performance, but the figures are insignificant at best.
                        2002 Subaru Legacy
                        1993 BMW 325i (sold)
                          Meat WagonM Offline
                          Meat Wagon
                          It works on the same principal as Methanol but just not as effective. Ethanol vaporizes with the incoming air to reduce intake temps. The reason need to run 50% more fuel is to have some ethanol injected into the combustion chamber after the vaporization has occured. Thats why on a car running methanol you don't need an intercooler or sometimes even a radiator. The cooler the air coming in, the more power you can make.
                          • 1990TSI1 Offline
                            1990TSI1 Offline
                            1990TSI
                            welcome, and nice car!
                            97 ek hatch gsr swap soon for boost, 97 ek coupe sold!, 97 ek coupe winter beater/ rally racer, 94 eg coupe, 94 eg coupe, 94 civic coupe RHD project finished!, 94 eg sedan parts car, 94 dc teg parts car, 92 gsr parts car, 92 eg hatch sold!, 91 da parts car, 91 integra sold!, 89 civic hatch sold!, 90 awd talon-sold, 91 fwd tsi parts car-crushed!! hahaha, 91 na eclipse-sold, 93 na eclipse-sold, 94 na dsm parts car
                              Props on using e85...i brought it up a couple times here and got shot down each time...love seeing someone use it!
                                PUREVIL-K20
                                ha ha Cory its looks like a monster as allways...
                                welcome to the forum.
                                2002 Acura nbp Rsx Type S
                                AEM SRI FS!
                                Tsudo Fireball Catback - on this week
                                Strup header - on this week
                                K-pro 8-12-06!!!
                                JDM blackhousing headlights
                                PIAA Xtreme white bulbs
                                Greddy Front lip
                                Type R rear lip
                                CW Sides, install ASAP
                                BC N+ sus
                                PIAA bulbs
                                Tinted windows
                                Painted Calipers
                                H emblems front and rear
                                C/F manifold cover
                                ARC intake
                                Skunk 2 shift knob
                                17x7 Nippon Gunmetal wheels 17lbs ea
                                Toyo 555 225/40/17 tires
                                19x8 n 19x9 inch ESTATUS ON TOYO 555 - For Sale
