  4. Problem with dsm.....lol
36 Posts 11 Posters 1.6k Views
  • PSiedTSiP
    PSiedTSiP
    yeah 25psi on stock fuel=BAD idea...
    spanish-rice;237125 wrote:
    • DrifterExtremeD
      DrifterExtremeD
      thats why i need a wastegate
        wastegate won't get you more fuel. Any idea what kind of AFR numbers you are running? Besides, 25psi on a stock turbo probably is a stupid idea, at some point all turbos run out of efficiency and just become huge heat pumps (this isn't a good thing) I dunno what the magic number is for DSM's, but I'm guessing 25psi is across that line.
        For more fuel look to a walbro Fuel Pump and some aftermarket injectors...and an SAFC or some other sort of fuel computer along with a wideband O2 to properly tune this thing.
        • JimJ
          JimJ
          ... This is why DSM's have a rep of being unreliable 🙂
          Well they are but still, 25 psi on stock fuel... Try that on any other car...
          • PSiedTSiP
            PSiedTSiP
            I'm guessing he just wants it to be stock...the wastegate obviously isnt opening at all...or if any just barely
            • DrifterExtremeD
              DrifterExtremeD
              I just found a wastegate and no i don't want to boost 25 i need it stock for now so i will replae the wastegate and see if it fixes my problem.
              • SmitEvoS
                SmitEvoS
                Silly noobs........
                • DrifterExtremeD
                  DrifterExtremeD
                  I hope that wasn't focused towards me because i don't by any means wish to boost some stupid amount... just run it stock for awile
                  • DelSlowD
                    DelSlowD
                    Matt= n00b :icon_compress:
                    • darkelvisD
                      darkelvisD
                      darkelvis
                      Ok, for those who aren't catching the e-sarcasm I will clear this up a little. Matt was getting horrible fuel cut in the DSM. The oh so reliable DSM boost gauge was telling him that he was getting fuel cut at only 7 psi so, we swapped in an aftermarket boost gauge and first gear spiked to 20 psi then held steady at 18 then in second gear the boost gauge ran all the way to 25 psi which is where he started getting fuel cut. According to the OEM gauge he was at 7 psi when this happened. And now we have the answer of bad wastegate. He is getting a new one to run the factory boost level (whatever the hell it is...I've heard 6 9 and 12) which is what he wants.
                      The whole thread is filled with sarcasm and it appears that not too many people are catching it. 🙂
                        Oh, I read it as he is TRYING to run 25 psi. My bad
                        • DrifterExtremeD
                          DrifterExtremeD
                          ^^^^^thanks for clearing things up.....lol dsms are sweet
                          • DelSlowD
                            DelSlowD
                            ^I love you matt^ Your e-penis is huge.
                            • darkelvisD
                              darkelvisD
                              darkelvis
                              Ok, I'm going to the fair now.
                              • DrifterExtremeD
                                DrifterExtremeD
                                hahaha...john have fun
                                • DrifterExtremeD
                                  DrifterExtremeD
                                  now can we get back on topic. So what would the whinning be coming from?
                                  • JoelJ
                                    JoelJ
                                    will is crying cuz u smacked him in the face with your e-penis. there is ur whining problem.
                                      stock turbo 25psi? I remember when I had my dsm 17psi was pushing it.
                                      • DrifterExtremeD
                                        DrifterExtremeD
                                        yea well that is now solved and i need to know why my tranny/transfer case whines?
                                        • 2slo50h2
                                          2slo50h2
                                          2slo50h
                                          The Whinnning isnt that bad.
                                          coughs...."KABOOM" is what Id be worried about.
                                          I would assume it is whinning for the same reason most transmissions do when they hit that sort of "I've been beat the hell out of for the first 100,000 miles of my life and now my time has come to spew tranny fluid and metal shavings all over the open road."
