  4. F/S: 1991 Dodge Stealth ES
16 Posts 3 Posters 1.7k Views
  • ericherm1E Offline
    ericherm1E Offline
    ericherm1
    Here are some pics of the interior and motor.
    More info:
    New plugs
    New Wires
    New Timing belt & all pullys + tensioner
    All new sensors, every sensor on the motor was replaced.
    SR'ed
    http://www.cardomain.com/memberpage/771392
      have you taken the pan off and looked to see if its in fact a bearing, if so how many?
      metal in the heads?
      why no pictures of the passenger side quarter panel dent?
        ericherm1E Offline
        ericherm1
        Don't know exactly what bearing or how many are bad. But have had this same problem before on different vehicles and its all the same sound. If its not a bearing then thats just less work that the buyer has to do. The topend work was done by Rydell in Grand Forks and heads were milled by MJ in Fargo.
        I totally forgot about the pics of the dent. I'll post some tomorrow. I got an estimate from Craig Amiot at 5-Star Collision & Glass Center for about $600 for a complete repair of the quarter.
        Its not leaking anything from the motor nor is it blowing any kind of smoke. No oil in the antifreeze. Its just knocking from the crank area which is indicative of a slipped bearing. Weather it be a crank or con-rod bearing I have no idea. Thats about as close as I can narrow it down without breaking it open.
        As it sits right now I'm done with the car. Any more work will be the responsibility of the buyer.
        I have also seen people dropping the VR4 into these cars with upgraded 2wd trannies to handle the extra hp....
        SR'ed
          ericherm1E Offline
          ericherm1
          Here's a few pics of the dent.
          SR'ed
            ericherm1E Offline
            ericherm1
            I'm willing to accept any reasonable offer, I need this car GONE!!
            SR'ed
              ill give you five hundred bucks today
                so it needs a new motor or no?
                  ericherm1E Offline
                  ericherm1
                  It would probably be cheaper to just replace the motor, but you could also have the bottom end rebuilt. The topend was just rebuilt and has been compression tested at 170 average for all 6 cyl. If you plan on doing it yourself, rebuilding it would be cheaper. For time crunching.. just replacing the motor is the fastest.
                  SR'ed
                    ericherm1E Offline
                    ericherm1
                    Still for sale... entertaining all offers!
                    Anything under $1000 buyer will have to arrange pickup, due to high gas prices.
                    The car will move under its own power, so loading onto a trailer or dolly is no problem.
                    SR'ed
                      there is nothing "fast" about replacing the motor:o
                        ericherm1E Offline
                        ericherm1
                        lol, I was compairing it too breaking it open and replacing the bearings. It only takes about a day to pull the motor and drop the other one in, thats if you don't disconnect the tranny.
                        SR'ed
                          ericherm1E Offline
                          ericherm1
                          Come on guys... you can make more than $1000 just selling the parts on eBay! I can't due to lack of space.
                          SR'ed
                            ericherm1E Offline
                            ericherm1
                            Passenger window is fixed, now only problems is slipped bearing and leaky Pwr Stearing.
                            SR'ed
                              ericherm1E Offline
                              ericherm1
                              sold
                              SR'ed
