240sx pics
97jeep wrote:
ya my dad is awsome, itll be turbo by the time MHS is out or ill take some more time and do some awsome wiring and that well take a while, remove all the unneed plugs and sensors on body harness and the wiring harness.
yea youre only 2 months behind so far -
ya i know.... had some problems the heads been off 5 times trying to fix an oil leak and final got that done, but done alot off stuff i wasnt planning on 2 and spent way too much time tring to make my speedo work all the time.
and then a i bought a car and fixed it to pay for more/better parts, i was going to do a getto/budget setup with afc and stuff and decided screw that, ill just do it once
loving the color, very clean engine bay and engine..
hahaha -
hehehe motor magic, well find out wont we. i somewhat started on it today, cut extra wires, removed fenderwells, removed stuff to get to ecu, do everything i can do and keep it driveable for aslongs as possible and then have a frenzy putting it together... probably tearing apart this weekend to start on IC pipes and fix the DP. and get it welded and stuff well i do the rest off it
hey im doing stainless(from magnaflow), just buying though dads shop. debating on mig welding it my self or just tack welding every thing and get it tig welded someplace in town, im going to screww around with some spare stainless this weekend and see how the welds turn out. when do u think ull be ready for it? if u can get your car down here
Im not possitive on whether or not the wire and gas in the welder can decently weld aluminum. but should be able to tack and then bring it to a welder to get welded the rest off the way, im considering just tac welding the pieces and bring them to get welded. im going to try a couple welds on some spare stainless and see how they turn out
