  4. a/c
a/c
9 Posts 6 Posters 794 Views
    a mechanic at a shop (will remain unknown) informed me that a check engine light (INSERT SHORT Story- stock ecu the a/c quit working and it did pull an o2 sensor code(s) but now that aem is in there are no cel's? aem certainly retains heat and a/c functionality) is more then likely the cause of my a/c not working.. is he serious or do i just come off as an idiot?:icon_scratch: the gauge reads full, the fan works, but the compressor does not turn on.
    i should mention that i had spent 400+ dollars there last fall replacing o-rings, charge lines, draining oil, recharging, and retrofitting for the new style refrigerant.... the swass has become unbearable!
      The compressor not turning on is probably the pressure switch. Try jumpering it out and checking if the compressor turns on. AC service is easy now that I learned how. 😄
        its not even a year old.. shitty luck?
        ..anything else to try?
          ahhh gotta love black leather.
            i do love black leather
            and your an asshat
              lets wrench on saturday, or bring it over to the shop tomorrow afternoon and we can do it there i guess too?
                could there be something cut or a switch not installed on your dash. something simple like that?
                  slowvo
                  sure a CEL could prohibit ac operation....i have no clue about your system but im guessing your ECM grounds a relay that sends power to 2 switches then goes to the AC compressor?
                  so,
                  where are you losing the ground?
                    Try jumpering the switch first.
                    BTW, pressure switches are not that expensive
