What should I go with???
Well my budget is depending on it i can sell my current car and then i will have a little more to spend.... I would like to run something faster. But i want to spend less then $1500. I have been talking to some people about the D series motor boosted and it sounds kind of kool..
96Talon wrote:
Well my budget is depending on it i can sell my current car and then i will have a little more to spend.... I would like to run something faster. But i want to spend less then $1500. I have been talking to some people about the D series motor boosted and it sounds kind of kool..Hands down, the best for your money.
PSiedTSi wrote:
You seem to have a good attitude towards stuff. Keep it up!
Thanks! I try to learn things and stuff like that before i step into something i dont know nething about. I dont think there is a better local forum then this to ask questions and recieve feedback..... -
I've said this like 50 times before when people ask for opinions on Honda swaps, and here is mine: complete LS motor/trans swap should run you less than $1000, or buy a whole wrecked integra to take everything out of and then part out the rest of the car, and then get some small slicks, and a small shot of nitrous like a 50 or maybe 75 shot, and you'll run low 13s for very little money. If you can find a good deal on a wrecked integra that you can part out, you will basically get all the parts you want for free, I've done it, twice.
treimche wrote:
Not to mention an LS motor is easily as fast as a B16, if not faster!
definitly agree. Way better and more usable power band... Then, eventually, U could always go LS-vtec.The b20 would be cool since no one has one around here... but It's gonna cost u more. U ever thought about a dual cam ZC swap. they make 140hp at the crank, same as an ls, and the cool thing is u can use your D series tranny! this way, U can save money by just buying the block.
A LS w/B16 tranny, now thats a good cheap combo. My JDM B16a from Hmotorsonline cost $1300 shipped w/Hasport mounts. Then you need, Clutch $250+, Flywheel resurfaced $35, Axles $200, Shift linkage $150, And I would say another $200 for fluids/seals/random shit.
I would say a full LS swap w/b16 tranny & clutch would run you around $1300 for a strong LS.
If I could do it all again I think I would have went with a 100% stock JDM D15b vtec. Hope this helps.
i have a buddy who is swappin a JDM D15b into his 91 crx si should be a nice little swap
BumpinJCC wrote:
^ Was that with axles ECU and all the goodies? If so thats a good deal, considering it came with hasports. That and where was it shipped to? Your door?
It was $1300 shipped to Matt's place w/ mounts. The swap + goodies cost me $2300 total.Axles, Haft shaft, Shift linkage, Exedy S1 clutch, CTR valve cover, Vison CF spark plug cover, Bronze DC headers, random nuts and bolts.
All and all I'm happy with it.:icon_thumright:
aliengotpsi wrote:
my .o2 buy a z6 or y8 and put head studs in and boost it too 10 psi or build it for around 1000.00 pistons/rods/bearings.... and run 20 psi+I made 250 whp on 10 psi and ran 12.2@113 tufte made 261whp and ran 11.9@113 there is no all motor B20's b18's b16's that can compete with the D16 boosted it would probly cost your about the same to do a swap or boost a D16..
My D16 now makes 400 whp depending which dyno your on some read low and some high.. and runs 11.5 @125
Looks like my d-16 hatch is the quickest and fastest honda around.!!!!
How does it stop and turn??
torbs wrote:
I believe he told me that he wasn't looking for boost. He's just looking for a good daily motor that can pull a low 14. A strong stock b16 will get that done for him. And judging by his budget, he doesnt have the $ to buy a d-series swap ($300-400 for a motor and $50-100ish for a Si tranny), buy the engine management (safc would be sufficient, which is cheap $100 for a used safc1), plus the turbo kit too...OBD0 b16 swap can be held for $1500...you just have to look. It's also a bit cheaper bc it's a cable tranny. He can also just then buy a stock JDM obd0 vtec ECU after swapping in the motor and be done...sure, is a boosted d-series faster? hell yea...but he didn't ask for anything that's crazy fast...just something quick that's fairly easy...B16 FTW!
and if nothing else, just say you bought the b16 bc it has CRAZY mad loud JDM VTACK y0:icon_cheers: :icon_thumright:
My .02 is b16/b18 with N2O. It is a daily driver and you want reliability just drop a stock motor and leave it stock and then spray at the drags. Done easy swap not retradedly expencive. It is a simple plan.
