  2. Introductions
  3. Introductions
  4. So... Here I am.
So... Here I am.
12 Posts 6 Posters 920 Views
    stirno
    out of pure boredom today I decided I'd finally register and post on FargoStreet. lol
    I drive a 1998.5 Audi A4 1.8T that just received a kick in the pants this weekend with a T-28 turbo upgrade. mmm.. New clutch and FMIC will be here next week. Hoping to get everything tied together to drag it a bit more this year.
    I'm sure people have seen me rolling around.. but ya.. my name is Brandon, thats my car, and I'm here now. lol
    1998 Audi A4 1.8T // T-28 // Koni Coilovers // European Spec Headlights (Ecodes) w/HIDs
    2007 VW GTI 2.0T // APR
    • 94NDTA9 Offline
      94NDTA9 Offline
      I was looking at a black A4 1.8T at imports plus. However, I have heard a lot of horror stories with them.
        looking good.... What sort of performance upgrade is the t-28? If you can't tell i don't know shit about audi's....:icon_monkey:
          stirno
          The T28 brings the power levels up to around 275hp@crank using the stock SMIC and exhaust from the stock rating of 150 for a pre-2000 1.8T (Drive-by-Cable cars).
            stirno
            such as? I've had this car for over a year now (23.5k miles on it since purchased).. No problems I didn't cause 🙂 If you maintain the vehicle properly it'll last forever -- which is pretty much the standard deal for any german car. Not like Hondas where you can abuse them forever before something breaks. lol
            Timing Belt every 60k miles, Water pump at the same time.. Replace the valve cover gasket when you buy it, stock ones leak.. Stock control arms tend to squeak loudly.. Check dealer service records to see if they were replaced, if not plan to spend the cash to buy the parts. They are relatively cheap. Some people have had problems with Coilpacks. If you have the BERU coilpacks on the car, you'll likely be fine.
            Also, the 1.8T (in all its forms) has been known to have an issue with oil sludge. Make sure the vehicle has received only Synthetic oil and that its using the larger sized oil filter. If its oil was changed at the dealership it'll be using the new filter size and Mobil1 0w40 oil.
            The 2.8 V6.. gotta be careful with it if you want to mod. Pre 1998, the 2.8 was a 12v V6 which is incredibly reliable if you dont mind oil burning/leaking slightly. Keep her topped off and it'll run forever -- Downside -- no real aftermarket for the engine. After 1998 the 30v V6 was introduced which has a few more options performance wise. There is a supercharger kit that achieves similar performance as my T28 kit on my 1.8T. Beyond that you're on your own.
            You have to be careful what you buy to make sure it was maintained well but if you are well educated before you purchase you can find some quality vehicles that'll last a long time.
              SLS is a local Neuspeed dealer if you need any parts :).
              Welcome!
              • 94NDTA9 Offline
                94NDTA9 Offline
                I have heard of alot of electrical problems with the 98 and 99's. Also, I heard it's a crap shoot if you buy them used because it's hard to know if it has had proper maintanence.
                  stirno
                  meh. its easy to know if its had proper maintenance. check for sludgy oil under oil cap and in PCV system and check the VIN @ an Audi Dealership to make sure it has gotten all the TSB work done on it.
                  As far as electrical issues.. Thats a rumor. 😜
                    How come you didnt go with the 2.7t? Nice car by the way!
                      nice car. got rid off the pee shooter stock turbo. they are a t-15 if i remember right. ive got one at my shop its pretty small
                        stirno
                        nope. k03 turbo stock. 😜
                          stirno
                          Welcome!
                          thanks for the welcome.. looks like we are both also on AwdAddicts too 😜
