  3. Track Talk
  4. Interstate Dragways Rules question
20 Posts 11 Posters 2.6k Views
    tranceman
    Just a few questions on Rules at the track..
    First off I am going to be running a convertible, am I going to catch any flak for that? I realize that i have to run with the top up. Is there anything special that I need being a convertible.
    Also in reading the NHRA rule book, convertibles that have an ET lower then 13.99 must have a driver restraint system. Is this rule enforced at the track? I am hoping to run lower then that. Will I get kicked out if I run faster then this without a 5 pt harness?
    Thanks in advance.
    1996 Mitsubishi Eclipse Spyder GS-T
    1992 Eagle Talon Tsi AWD
      I believe you need a cage at 13.99.......
      • DanglerD Offline
        DanglerD Offline
        Dangler
        • hondaking424H Offline
          hondaking424
          i thought it was 12's
          • dubbsyD Offline
            dubbsyD Offline
            used to be 13.99, this year the regulations changed to 13.49 (hardtops changed from 11.99 to 11.49).
            You'll almost deffinetly want a helmet for starters (not sure they'll let verts run w/o helmet period) and I think it'll all depend on who's working if you get the boot for running too fast. IIRC there was a cobra out there running sub 11.49 and he got talked to a couple times but I don't think he was ever booted.
              tranceman
              I had planned on bringing a helmet already. Looking at the rules I dont see anything in particular other then the Roll bar at 13.49 and the 5pt harness at 13.99 and under. I have neither of course. :icon_blackeye:
              • M Offline
                M Offline
                moparguy
                You will need a helmet and the top up. Faster than 13.99 and the driver does need a harness. The track is a NHRA track and if anything were to happen to someone that was allowed to go down the track illegal to nhra rules, then the track would lose its NHRA status. so it is enforced quite a bit.
                If you havent run before you will also need long pants and at minimum a tshirt, preferably a long sleeve shirt, or we will turn you around and send you out until you change.
                Hope this helps you out alittle bit.
                • Suby701S Offline
                  Suby701S Offline
                  Suby701
                  Does eveyone that runs need a helmet or just the convertable guys.
                  02 Aspen White Subaru 2.5RS: Full exhaust, CAI, Cobb Spicey Cams, Pulley, Flywheel, STS, RSB, Perrin P.S.R.S., Springs, 98 Goldies wrapped in Hankook RS-2's, Jun eyelids, WRX hood, Hella 500's
                  04 Ninja 250 (SOLD)
                  04 Buell XB12R w/ Race Kit (SOLD)
                  06 Triumph Speed Triple (Arrow Exhaust & Tune)
                    tranceman
                    Thanks for the clarification!
                    I should be all set now.
                    • JoKeRJ Offline
                      JoKeRJ Offline
                      JoKeR
                        while were on it how bout battery rules?
                        • M Offline
                          M Offline
                          moparguy
                          The battery do need to have a hold down, and no, a bungee cord does not work. I tried that one myself once. it didnt work. If the vehicle has a trunk mounted battery, I beleive it needs to be in a mounted battery box, and im not sure exactly on this one but i beleive it needs to have a firewall between the battery and the driver. I dont know all the rules, I just announce there.
                            i wassed tech with a bungee strap, but i am wondering about the in the battery in the back people have told me i will pass and people tell me it wont, the people that tell me it wont.
                            • fallguyF Offline
                              fallguyF Offline
                              fallguy
                              moparguy-Do you think that the track will be prepped enough to maybe run some 9's early? I would like to maybe let it rip a few times and maybe even run an 8 if the track will hold early on.
                              1990 Ford Probe GT 2jz RWD
                              • M Offline
                                M Offline
                                moparguy
                                It really depends on the weather and if we can get enough heat in the track early on. But I'll see what we can do for ya. Its the best I can offer for ya. Im thinking if we start right at 12 around 1 or so there would be enough heat in the track to give er a rip.
                                  I've helped people pass tech because I had a roll of Duct tape to tape down the battery on a street legal day. The tech gave him the idea.
                                  • JoKeRJ Offline
                                    JoKeRJ Offline
                                    JoKeR
                                    I used a bungee strap to pass tech in june street legal weekend... just strapped on the bungee and the guy said good to go... and walked to the next car.
                                    • JoKeRJ Offline
                                      JoKeRJ Offline
                                      JoKeR
                                      what time does this thing start at this mourning anyways??
                                        10:00am
                                        • JoKeRJ Offline
                                          JoKeRJ Offline
                                          JoKeR
                                          k thx man
