  4. launching
launching
31 Posts 14 Posters 1.2k Views
    I launch at 7000 rpm. It does burnouts.
      Liar
      • capitljC Offline
        capitljC Offline
        capitlj
        You guys are nuts. Its impossible to launch to a FWD car, well just look at the setups on the fwd drag cars there is a lot of technology and engineering in those front ends and they are still quite a bit slower than a RWD with the same power and tires. But there is way to get faster launches and honestly are those high rpm launches faster? Lower your tire pressure, it can shave a few tenths off you 60 foot and thats where you FWD guys need it. Bone up on the concept of weight transfer. Stiffening up you rear suspension will make the car squirrely at the long end but you'll get much better launches and keep the front planted. If you can adjust you ride height put the back in the air, there is a reason muscle cars have a rake. Its a delicate balance between ride quality and speed but who care about a sore ass at the end of the day. Obviously i can only give you a little bit of info in this particular arena but read, there are some pretty good tech articles in Modified Mag and the like. You can always ask some of the guys in town who have drag racers the concepts all apply except in reverse, you want to keep weight off the rear to get traction.
        > Mitch Hedberg wrote:
        2004 Impala LS 3.8
          Pretty sure I've got the FWD thing down.... not too many 10 second FWD street cars in this state......
              So then tell "theoblivious" how to do it, that's what the thread is about.
              It's all about NOT spinning the tires. Obviously if your tires are spinning, then you're not going as fast as you could. You really just need to find the balance between spinning and bogging. If it means slipping the clutch to keep RPMs up and in your power band, then so be it. It would help if you posted up what car, what mods, what tires, and your current launch technique.
                Get some good tires!
                It depends on the car, the power your making etc... but rev it up, slip the clutch a bit till you feel it catch slightly and then get the hell out of first so you might have a chance to hook it up
                • theobliviousT Offline
                  theoblivious
                  ticklemedaly wrote:
                  hows school going? did your parents get the ipod to ya?
                  school is going awesome. Its gonna be a ton of work already.
                  I got the Ipod thanks! Miss bein in moorhead though.
                  BOOST....to be continued
                    theoblivious
                    on gsr. i used to rev to 4500 and slip the clutch. Grabbed great On the rsx i t has a rev limiter before vtec so i bounce of that and floor the gas and slip the clutch. It has shitty tires. I guess Im asking just on technique itself thats universal to all manual fwd cars. Do you slip clutch more or do you not fully throttle the gas? Do you just try to burn through 1st (only first in my case) or should you start in 2nd?
                    Kenn
                    • capitljC Offline
                      capitljC Offline
                      capitlj
                      It's different for every car and setup just pay for a track day sometime and try different techniques until you find the sweet spot. Oh and integra gsr whats your 60 foot time you dont have that in your sig. I'm sure all your speed comes in at the far end on the track right, not that your slow off the line but i bet you could be a lot faster if you could launch without roasting the tires.
                      2004 Impala LS 3.8
                        1.766 was his 60' and a .002 reaction as well. The 1.7 can be improved on, no doubt, but its still not awful
                          When I ran a FWD car on small slicks, I launched almost exactly how I launched my DSM. Slip the clutch until you feel the car moving, and then dump the clutch from there. If you have a weak clutch, it will just burn, but if you have a good clutch, it should take off nicely.
                            theoblivious
                            alright cool guys thanks for all the help!
                              So you are telling me that a mustang or slomaro with 400ish whp can run low 11's (using kevin's hatch as an example)...
                              ok
                              and as far as launching goes...rev limiter...drop 😉
                              actually, I launch at around 4-5k...just depends on how much i wanna spin the tires (my sweet ass steelies y0)
                                ok
                                not sticking up for capitalj...but yes..if a mustang weighed the same as a civic did and it had 400hp...it would run low 11s
                                  my point is that a mustang with 400whp cant due to it's weight...my point was just that a civic with 400whp is faster than a mustang with 400hp...if you go power to weight ration and make them the same, then that's another story
                                    This is such a stupid argument. Weight is no the only factor. Traction, gearing, driver and suspension setup all play into it. There are mustangs with 400hp running low 11s.
                                      bc you've never said anything stupid...EVER...:p
                                        Nevar!
                                        The whole argument is stupid though. Like I said, there are a ton of factors plaing into it that are not even mentioned.
                                        • capitljC Offline
                                          capitljC Offline
                                          capitlj
                                          Indeed.
                                          2004 Impala LS 3.8
