  3. Track Talk
  4. Looking for a pontiac 455
57 Posts 14 Posters 9.5k Views
  • capitljC
    capitljC
    capitlj
    No i havent thats just what i hear from people who do as far as cold starts go. The only reason i said anything at all on this thread was because someone said a big block would be cheaper than a small block thats just plain madness.
    Mitch Hedberg wrote:
    2004 Impala LS 3.8
    • 94NDTA9
      94NDTA9
      LightEmUp wrote:
      Man....... you guys are getting into stuff I didn't want to know, I will be putting a <u>pontiac</u> 400 or 455 whether I bore it out or not which I probably will. I have some hookups through my dad, he knows some people in the auto business, but anyways im not that worried about price all I asked does anyone have a 455 you guys took it out of the park around the block and then some, o well also does anyone have a winter beater car for me so i can actually rip the 400 out of the car so I can get it rebuilt if no has a 455 well you guys have fun with that LS shit
      Putting in a crate LS1 is going to be a hell of a lot easier to get running right than a carbed 400 or 455.
      But I would rather get as 455 too. Don't even bother with a 400.
      • LightEmUpL
        LightEmUpL
        LightEmUp
        Yeah I really want to go with the 455 but it is so hard to find a pontiac 455 that is an early 70's those are the ones with the most horsepower If I end up going with the 400 it wont be so bad because i will be able to put better parts on it with the money I will be saving from not buying the 455 and I think a 455 has more expensive parts, but most parts are able to go on either what ever I do it will be sweet and it will definately be mean as hell
        1975 Trans am 455 8.99 @158mph (What now fallguy)
        1987 CRSEX W/Fucking VVVVVVVVV-TEC (But is now sitting in a junk yard cuz I blew it up......Ooops!!)
        2001 cr125 (Faster Than LoveMachines Bike)
        • MisterCMKM
          MisterCMKM
          You can get a 455 block out of any pontiac. Throw an aftermarket set of heads on there, bore it and stroke it and you're easily over 500hp.
          thrash;315544 wrote:
          Ford is back :)
          • 94NDTA9
            94NDTA9
            QFT.
            The only reason the older ones have more power is because of the exhaust, carb and cam. If you plan on swapping that out anyways, might as well pick up any 455 you can.
            • capitljC
              capitljC
              capitlj
              Not quite guy you gotta have a good carb to feed all those cubes and some headers to manage the flow. Plus a good set of aftermarket heads are well over $800 per side. If possible work the stock heads most BB heads can have bigger valves stuffed in then do the engine work should save you a solid $500 but it wont be cheap, and you'll have to do your homework. Best way to do that is to ask guys who have already done it.
              2004 Impala LS 3.8
              • MisterCMKM
                MisterCMKM
                The stock q-jet is good up to 500 or so hp. The Ram Air IV manifolds are just as good as a set of headers. I forget which casting it is, but the stock Pontiac heads with a little porting and polishing are exactly what aftermarket heads are designed after.
                Come back when you learn something about the pontiac motors.
                Ford is back :)
                • T
                  T
                  tqisking
                  I really wish people would quit calling the pontiac engine a Big Block...it is not all pontiac engines 326-455 are all physically the same size, period....
                  This is simple
                  Take your 400 out ( or buy another block, I may have a couple) Bore it to 4.150 (.030 over)
                  Buy a eagle 3" main 4.250 stroke crank ($299) buy a set of 6.8" BBC rods and the correct piston for the stroke and rod for a deck height of 10.220". You can buy this rotating assembly balanced and ready to go (besides cleaning) for $2000.00
                  As far as heads are concerned go and find some 6X -4 castings the -8's are ok also but they are a lower compression, send them to a shop for a street strip port job, I suggest Butler performance in lenoma TN www.jbp-pontiac.com ....They will get you set up, just tell them what you are looking for, I always talk to David Butler, super nice guy and he is very helpfull.
                  Camshaft just go with a extreme energy from Comp Cams, you will have to know what size engine you are going with first and what the heads flow...
                  I would try and get a 850 cfm carb on it with a single plane manifold and some 1 7/8" headers if you go with the bigger engine
                  All in all plan on around $4000-$5000 for 500-550 hp and more tq than you can hook up, nice thing is that you will not have to spin the snot out of it so it will last a long time, but be prepared all that tq will find you weak spots 🙂
                  But what do I know? hehe
                  Chad
                  • T
                    T
                    tqisking
                    ps do not bore it until you have the pistons so you can measure them for the correct fit...I could assemble one for you if you need it
                    • MisterCMKM
                      MisterCMKM
                      Yup, like I said.
                      MisterCMK wrote:
                      BTW, there is no "big block" or "small block" with the pontiac motors. They are all the same physical size.
                      Ford is back :)
                      • capitljC
                        capitljC
                        capitlj
                        Big block or not there is no way a stock quadracrap could feed 500 horses it would at least have to be rebuilt for more cfm, and the stock manifolds might get you the numbers but numbers aren't good for anything but bragging. You want that motor to continue building power as the RPM's go up, with stock manifolds it will fall on its face at about 4000-5000 RPM ported or not. Maybe there are some good factory cast iron headers like you get on 89-up 5.0 stangs those might work.
                        2004 Impala LS 3.8
                        • MisterCMKM
                          MisterCMKM
                          d00d, you obviously know nothing aobut the pontiac motors. Give it up.
                          The motors don't have to spin high to make all their power. They make the power down low.
                          Seriously though, give it up.
                          Ford is back :)
                            I'm thinking Chad (tqisking) knows a bit about this subject, you might wanna leave the technical aspect of things to him.
                            Having said that, I still vote for a 2JZ swap.
                            • T
                              T
                              tqisking
                              Here is a 600hp pump gas Poncho if you are interested
                              http://forums.performanceyears.com/forums/showthread.php?t=492069
                              Chad
                              • capitljC
                                capitljC
                                capitlj
                                I'm giving up ha not really 5k is not spinning the motor high unless you have a stick or and auto with a shift kit like i dont your tranny will run the motor up to at least 5k before shifting with the pedal to the floor, My 5.0 literally falls on its face after 4k and then i have to wait another thousand RPM before it shifts its frustrating as hell, and that motor for sale is definatly worked over a lot more than what you guys are talking about. I can see aluminum heads, at least $1600, headers on the floor, high rise intake manifold, really shiny fuel pump, and all that makes 600hp. No way you could get over 500 with the stock manifolds, carb, and heads even if they are worked you just wont get the flow through those manifolds. Come on guys i might be wrong but its not for the reasons your giving.
                                2004 Impala LS 3.8
                                • MisterCMKM
                                  MisterCMKM
                                  I'm done arguing with you. Go read here. http://boyleworks.com/ta400/index.html
                                  All that I am saying is that the RA IV manifolds are supposed to flow as well as a pair of headers. The later quadrajets are up to the task of handling the power. The earlier model q-jets were 750cfm, the later ones are 800. As far as heads go, some of the pontiac heads are great with just a port/polish. The stock parts on pontiac motors have a lot of potential in the hands of someone who knows what they are doing.
                                  Ford is back :)
                                  • T
                                    T
                                    tqisking
                                    You are correct!!!!
                                    The only thing about the RA manifolds is that they are about as good as a set of 3 tube headers (2 center ports are one tube)... So he would be better off getting a cheap set of 4 tube headers, and probably a performer rpm intake. The Q-jet will work fine for 500hp, but will most likely need calibration. It seems though that the person who originally asked this question is not here anymore???
                                    • T
                                      T
                                      tqisking
                                      Have you ever seen the size of your exhaust ports on your 5.0?
                                      Anyway if you have a pontiac transmission it will more than likely be calibrated to shift at the correct rpm (low probably 5200rpm dont remember) And you were wrong about the heads they are closer to $2500, and that high rise intake is a victor about the only decent intake that you could buy for a "big" engine untill recently, also that is not a fuel pump it is a regulator...
                                      I am pretty sure nowhere did he say that he wanted to run factory manifolds, did he?
                                      What would it take for 480-500hp
                                      455 cubic inches
                                      a camshaft in the 246 @ .050 and 253 @ .050 around .500-.550 lift
                                      A good factory intake would be ok but as I said earlier the RPM would be a better choice
                                      A set of good factory heads with a good clean up and valve job(what casting number would depend desired compression ratio)
                                      Cheap 4 tube headers
                                      That is about it you would make 480-500 hp around 5500 rpm maybe a little less..
                                      You do not have to spin the chit out of a engine to make power or be fast you just have to get the combo right
                                      Chad
                                      • MisterCMKM
                                        MisterCMKM
                                        tqisking wrote:
                                        You are correct!!!!
                                        I've heard there are fitment problems with the shaker scoop and a performer rpm intake.
                                        Ford is back :)
                                        • MisterCMKM
                                          MisterCMKM
                                          Thank you tqisking for finally putting him in his place. Hopefully he will believe someone else who knows about pontiac motors.
                                          On another note, we will be building a 400 to put in our 75 Trans Am this winter. I'll have to make a thread documenting the build.
                                          Ford is back :)
