Looking for a pontiac 455
Man....... you guys are getting into stuff I didn't want to know, I will be putting a <u>pontiac</u> 400 or 455 whether I bore it out or not which I probably will. I have some hookups through my dad, he knows some people in the auto business, but anyways im not that worried about price all I asked does anyone have a 455 you guys took it out of the park around the block and then some, o well also does anyone have a winter beater car for me so i can actually rip the 400 out of the car so I can get it rebuilt if no has a 455 well you guys have fun with that LS shit
Putting in a crate LS1 is going to be a hell of a lot easier to get running right than a carbed 400 or 455.But I would rather get as 455 too. Don't even bother with a 400.
Yeah I really want to go with the 455 but it is so hard to find a pontiac 455 that is an early 70's those are the ones with the most horsepower If I end up going with the 400 it wont be so bad because i will be able to put better parts on it with the money I will be saving from not buying the 455 and I think a 455 has more expensive parts, but most parts are able to go on either what ever I do it will be sweet and it will definately be mean as hell
MisterCMK wrote:
You can get a 455 block out of any pontiac. Throw an aftermarket set of heads on there, bore it and stroke it and you're easily over 500hp.
QFT.The only reason the older ones have more power is because of the exhaust, carb and cam. If you plan on swapping that out anyways, might as well pick up any 455 you can.
Not quite guy you gotta have a good carb to feed all those cubes and some headers to manage the flow. Plus a good set of aftermarket heads are well over $800 per side. If possible work the stock heads most BB heads can have bigger valves stuffed in then do the engine work should save you a solid $500 but it wont be cheap, and you'll have to do your homework. Best way to do that is to ask guys who have already done it. -
The stock q-jet is good up to 500 or so hp. The Ram Air IV manifolds are just as good as a set of headers. I forget which casting it is, but the stock Pontiac heads with a little porting and polishing are exactly what aftermarket heads are designed after.
Come back when you learn something about the pontiac motors.
I really wish people would quit calling the pontiac engine a Big Block...it is not all pontiac engines 326-455 are all physically the same size, period....
This is simple
Take your 400 out ( or buy another block, I may have a couple) Bore it to 4.150 (.030 over)
Buy a eagle 3" main 4.250 stroke crank ($299) buy a set of 6.8" BBC rods and the correct piston for the stroke and rod for a deck height of 10.220". You can buy this rotating assembly balanced and ready to go (besides cleaning) for $2000.00As far as heads are concerned go and find some 6X -4 castings the -8's are ok also but they are a lower compression, send them to a shop for a street strip port job, I suggest Butler performance in lenoma TN www.jbp-pontiac.com ....They will get you set up, just tell them what you are looking for, I always talk to David Butler, super nice guy and he is very helpfull.
Camshaft just go with a extreme energy from Comp Cams, you will have to know what size engine you are going with first and what the heads flow...
I would try and get a 850 cfm carb on it with a single plane manifold and some 1 7/8" headers if you go with the bigger engine
All in all plan on around $4000-$5000 for 500-550 hp and more tq than you can hook up, nice thing is that you will not have to spin the snot out of it so it will last a long time, but be prepared all that tq will find you weak spots
But what do I know? hehe
Chad
tqisking wrote:
I really wish people would quit calling the pontiac engine a Big Block...it is not all pontiac engines 326-455 are all physically the same size, period....Yup, like I said.
MisterCMK wrote:
BTW, there is no "big block" or "small block" with the pontiac motors. They are all the same physical size. -
Big block or not there is no way a stock quadracrap could feed 500 horses it would at least have to be rebuilt for more cfm, and the stock manifolds might get you the numbers but numbers aren't good for anything but bragging. You want that motor to continue building power as the RPM's go up, with stock manifolds it will fall on its face at about 4000-5000 RPM ported or not. Maybe there are some good factory cast iron headers like you get on 89-up 5.0 stangs those might work.
capitlj wrote:
Big block or not there is no way a stock quadracrap could feed 500 horses it would at least have to be rebuilt for more cfm, and the stock manifolds might get you the numbers but numbers aren't good for anything but bragging. You want that motor to continue building power as the RPM's go up, with stock manifolds it will fall on its face at about 4000-5000 RPM ported or not. Maybe there are some good factory cast iron headers like you get on 89-up 5.0 stangs those might work.I'm thinking Chad (tqisking) knows a bit about this subject, you might wanna leave the technical aspect of things to him.
Having said that, I still vote for a 2JZ swap.
Here is a 600hp pump gas Poncho if you are interested
http://forums.performanceyears.com/forums/showthread.php?t=492069
Chad
I'm giving up ha not really 5k is not spinning the motor high unless you have a stick or and auto with a shift kit like i dont your tranny will run the motor up to at least 5k before shifting with the pedal to the floor, My 5.0 literally falls on its face after 4k and then i have to wait another thousand RPM before it shifts its frustrating as hell, and that motor for sale is definatly worked over a lot more than what you guys are talking about. I can see aluminum heads, at least $1600, headers on the floor, high rise intake manifold, really shiny fuel pump, and all that makes 600hp. No way you could get over 500 with the stock manifolds, carb, and heads even if they are worked you just wont get the flow through those manifolds. Come on guys i might be wrong but its not for the reasons your giving.
I'm done arguing with you. Go read here. http://boyleworks.com/ta400/index.html
All that I am saying is that the RA IV manifolds are supposed to flow as well as a pair of headers. The later quadrajets are up to the task of handling the power. The earlier model q-jets were 750cfm, the later ones are 800. As far as heads go, some of the pontiac heads are great with just a port/polish. The stock parts on pontiac motors have a lot of potential in the hands of someone who knows what they are doing.
MisterCMK wrote:
I'm done arguing with you. Go read here. http://boyleworks.com/ta400/index.htmlAll that I am saying is that the RA IV manifolds are supposed to flow as well as a pair of headers. The later quadrajets are up to the task of handling the power. The earlier model q-jets were 750cfm, the later ones are 800. As far as heads go, some of the pontiac heads are great with just a port/polish. The stock parts on pontiac motors have a lot of potential in the hands of someone who knows what they are doing.
You are correct!!!!
The only thing about the RA manifolds is that they are about as good as a set of 3 tube headers (2 center ports are one tube)... So he would be better off getting a cheap set of 4 tube headers, and probably a performer rpm intake. The Q-jet will work fine for 500hp, but will most likely need calibration. It seems though that the person who originally asked this question is not here anymore???
capitlj wrote:
I'm giving up ha not really 5k is not spinning the motor high unless you have a stick or and auto with a shift kit like i dont your tranny will run the motor up to at least 5k before shifting with the pedal to the floor, My 5.0 literally falls on its face after 4k and then i have to wait another thousand RPM before it shifts its frustrating as hell, and that motor for sale is definatly worked over a lot more than what you guys are talking about. I can see aluminum heads, at least $1600, headers on the floor, high rise intake manifold, really shiny fuel pump, and all that makes 600hp. No way you could get over 500 with the stock manifolds, carb, and heads even if they are worked you just wont get the flow through those manifolds. Come on guys i might be wrong but its not for the reasons your giving.Have you ever seen the size of your exhaust ports on your 5.0?
Anyway if you have a pontiac transmission it will more than likely be calibrated to shift at the correct rpm (low probably 5200rpm dont remember) And you were wrong about the heads they are closer to $2500, and that high rise intake is a victor about the only decent intake that you could buy for a "big" engine untill recently, also that is not a fuel pump it is a regulator...
I am pretty sure nowhere did he say that he wanted to run factory manifolds, did he?
What would it take for 480-500hp
455 cubic inches
a camshaft in the 246 @ .050 and 253 @ .050 around .500-.550 lift
A good factory intake would be ok but as I said earlier the RPM would be a better choice
A set of good factory heads with a good clean up and valve job(what casting number would depend desired compression ratio)
Cheap 4 tube headersThat is about it you would make 480-500 hp around 5500 rpm maybe a little less..
You do not have to spin the chit out of a engine to make power or be fast you just have to get the combo right
Chad
tqisking wrote:
You are correct!!!!The only thing about the RA manifolds is that they are about as good as a set of 3 tube headers (2 center ports are one tube)... So he would be better off getting a cheap set of 4 tube headers, and probably a performer rpm intake. The Q-jet will work fine for 500hp, but will most likely need calibration. It seems though that the person who originally asked this question is not here anymore???
I've heard there are fitment problems with the shaker scoop and a performer rpm intake.
