  4. Is this bad? *PICS*
Is this bad? *PICS*
13 Posts 10 Posters 879 Views
    So I took off the oil pan on the LS block I just bought and my heart dropped... What should I think of this... He said that it has never had oil ran through it so I assume thats why it's rusty, but what if it flaked off inside, or something else hppened... What woudl you guys do? BTW, its just surface rust, and it flaked off very easily once I took it out.
      I can't pull up the pic. It says:
      Error
      We're sorry, this page is temporarily unavailable. We apologize for the inconvenience. Please try again later.
      • darkelvisD Offline
        darkelvisD Offline
        darkelvis
        Error
        same
          same.
              tqisking
              I think I would ge a new pick up.....I hope the rest does not look like that
              • 9 Offline
                9 Offline
                97lt1
                That motor will atleast need to be torn all the way to the block and cleaned really good.
                  The Rest doesn't it all looks clean and new. It kinda looks like the machine shop installed everything and lightly oiled it all, and then he put the new pil pickup on and the baffle and pan and didn't put any oil on it to keep it from rusting. The Motor was kept upside down w/o a head or an oil drain plug.
                  • 9 Offline
                    9 Offline
                    97lt1
                    Well if it's just the pickup tube that looks like that I would try to clean it up really good and see what it looks like. If it doesn't look good after cleaning it I would just buy a new one.
                      holy scat, good luck with that, i hope the rest isnt like that.
                      • GarageAlchemistG Offline
                        GarageAlchemist
                        that woulda scared the piss outta me
                        97 GTi, 03 KJ
                          It looks good to go, just put it together and run it............... if you want to waste your time and money yanking it and having to rebuild it again. You should really have the whole thing disassembled and cleaned, then have the machine shop measure EVERYTHING before it goes back together to make sure it's all been done properly. Do it right or do it twice.
                            TESTIFY!!!!!
