  4. Miata head gasket
Miata head gasket
15 Posts 5 Posters 3.8k Views
    MisterCMK wrote:
    Have you done a compression test on the car to see if it is indeed a headgasket?
    A compression test isnt a failsafe way to detect a blown headgasket.
      which also leads me to wondering what makes you think it is blown? Not a common problem in the Miata 1.6 or 1.8.
        yes, I know that, but its a good indicator of one.
        • BookemB Offline
          BookemB Offline
          Bookem
          I mentioned to the guy we should do a compression test, but it is using coolant pretty fast(half a gallon every hundred miles or so) it's not leaking externally and it was overheated for an extended period of time, plus I like tearing stuff apart....lol I just got done replacing a head off of a dodge minivan due to a horrible engineering defect, and dsm is off the hook on this one it wasn't the 3.0 it was the 3.8 which is also not mopar, it is made by cummins which I thought was odd since it wasn't a diesel, but their plant in mexico makes gas engines
          Legacy GT
          Gmc Suburban
          Hallorann: Fargostreet?
          Hallorann: No, I ain't.
            is there a coolant passage in the intake mani and throttle body wes?
              Throttle body?.......On my 1.6 there is. Notsure on the 1.8 though. I would assume so.
                I take that back. No there isn't one on either engine.
                • BookemB Offline
                  BookemB Offline
                  Bookem
                  Just curious if anyone has a head laying around for that miata? 94 1.8
                  Legacy GT
                  Gmc Suburban
                    Talk to Nick at Straightline specialties. He did have one. Not sure if he still does though.
                    • BookemB Offline
                      BookemB Offline
                      Bookem
                      Alrighty, thanks Wes, anyone know how late they are open tonight?
                      Legacy GT
                      Gmc Suburban
