  4. riddle
riddle
70 Posts 23 Posters 3.1k Views
  • XJHEADX Offline
    XJHEADX Offline
    AFSil80 wrote:
    Lift has nothing to do with how much thrust. .
    Yes, you are correct there. The engines are pushing the A/C forward the tires are not making it go forward.
    AFSil80 wrote:
    It's all about the windspeed hitting the leading edge..
    I think you better do a little more research on lift.
    AFSil80 wrote:
    So again, if the wheels are freerolling and the conveyor belt is doing the same, the plane won't move. ..
    Let me ask you this, how will the conveyor even start to rotate if the plane has not even moved forward, explain that one to me??
    AFSil80 wrote:
    The wheels keep the airplane supported until it builds up enough airspeed for the bernoulli effect to take place...
    I agree that is one reason, the other is that it would create alot of havoc during landing w/out them...
    AFSil80 wrote:
    If it can't hit that speed, and it won't while it sits on a belt that can keep up, there will be no forward motion.
    It will hit that speed..
    Let us look at this way, say you put a bicycle on a treadmill, and you push it forward and the treadmill begans to speed up at the same rate as the tires, not at the rate you are pushing it. With this concept are you stating that you will not be able to push the bike off the treadmill pushing forward????
    AFSil80 wrote:
    You have to think out of the box on this, and a little knowledge of aircraft helps..
    I think 5 years in the Marine Corps working on the flight line troubleshooting F-18 fighter jets maybe makes me a little bit qualified here. Not just watching them take off and land like you and listening to other people who have no clue as to what the fuck they are talking about...
    Enough said,, probally not let's hear it...
      • ColinC Offline
        ColinC Offline
        Colin
        the plane will take off, the converyor belt will simply make the wheels spin faster realative to the speed of the forward motion of the jet and the reverse motion of the conveyour belt.
        because the thrust of the jet engine is pushing the plane forward, and the wheel axels are free spinning, once the applied friction of the wheels to their axels is negated by equal force from the thrust, the plane will make forward motion until it reaches speed to make lift, then if will fly.
          I think its safe to say that me and Bill just killed this topic
          • XJHEADX Offline
            XJHEADX Offline
            AGREED:icon_salut:
              Anyone else wanna tell us why this what we have posted is false?
                more proof
                http://videos.streetfire.net/player.aspx?fileid=35E964D9-38DB-4EFD-BE8D-D6BA1A43A06B
                • Afsil80A Offline
                  Afsil80A Offline
                  Afsil80
                  Is there windspeed acting on the plane as a result with the thrust being provided?
                  -Peter
                  1991 240SX
                    There will be lift after the plane reaches a certain speed....
                      No, there is windspeed acting on the plane as it moves forward which is a result of the thrust pushing the plane forward. The plane doesn't care that its on a conveyor belt, so long as the wheel can spin and the plane isn't bolted to the conveyor belt, it will take off because it will be moving fast enough IN RELATION TO THE GROUND to cause air to flow over the wings thereby causing lift. Case closed.
                      • XJHEADX Offline
                        XJHEADX Offline
                        pulled this off another sight, I post on, same subject
                        Honestly, do some of you have audio implants to remind you to breath for fear of dying or WHAT?????
                        • Afsil80A Offline
                          Afsil80A Offline
                          Afsil80
                          No, I know how it works. I was simply using the leading edge of the wings as a reference. Downforce on top, lift on the bottom.
                          It won't. I know that.
                          And a lot of unneccesary work for me, haha.
                          But isn't that the whole point of the argument? To see if an a/c will take off while the surface the wheels rest on move in the opposite direction at the same speed, aka, being stationary? If that is not the point of the argument, or there is some other factor that hasn't come clear, then I have been arguing for the wrong side.
                          Not saying you're unqualified, or saying that I'm overqualified. And I do more than just watch them take off. I work flightline as well. I'm a structural mechanic, aerodynamic smoothness and structural integrity for the a/c is a critical part of my job.
                          -Peter
                          1991 240SX
                            i spent an hour last night explaining it to him as well. Peter, you have been owned accept your defeat and raise the white flag and run.
                            • Afsil80A Offline
                              Afsil80A Offline
                              Afsil80
                              Not admitting defeat quite yet, I think I missed something, check bold print in my last post.
                              -Peter
                              1991 240SX
                                I realize that an Aircraft Carrier doesn't move very fast, but a plane could easily take off from that without any adverse effects...
                                  the wheels could spin 2000000000000000000000000000 miles an hour BACKWARDS and it will not be enough to keep the 90,000 lbs of thrust from pushing the piece of sheetmetal that is a plane forward. the wheels are a BEARING doing nothing but reducing friction.
                                    The point is it doesn't matter if the wheels are at rest, spinning forward or spinning backwards, so long as the plane is moving forward in relation to the ground it will take off....and a conveyor belt will not stop it from doing so if it is pushing on the free spinning wheels which have no affect on if the plane can move regardless. What you are failing to see is that the aircraft IS NOT STATIONARY, it is being propelled forward (in reference to the ground) via prop or jet turbine (or any sort of forward propulsion mechanism) and the conveyor is moving at the same speed backwards thereby causing the wheels to spin twice as fast which has ZERO affect on the planes ability to move forward.
                                      Now think about this, can a float plane (airplane with water landing gear) take off against the current? The answer is yes, so long as it can overcome the friction of the water.
                                      • Afsil80A Offline
                                        Afsil80A Offline
                                        Afsil80
                                        It just clicked in my head, for some odd reason.
                                        I think as I kept reading you and xjhead posts, and completely removed the wheels from the equation, it makes total sense.
                                        :icon_salut: to you and xjhead. I retract most of my statements from earlier.
                                        -Peter
                                        1991 240SX
                                        • XJHEADX Offline
                                          XJHEADX Offline
                                          above post at 0307
