  3. Track Talk
  4. 2007 Interstate Dragways Street Legals
44 Posts 13 Posters 5.3k Views
    It is but you don't have to partake. I just run test and tune.
      WTF? I honestly didn't know that! That's flippin great!
      • BlueSRT0483B Offline
        BlueSRT0483
        So even though bracket racing is going on.... You can still test/tune; what is the costs? I'm assuming obviously more, but w/o the TM street legals, I'm not going to cry over that if test/tune reglar weekends are available.
        2004 Dodge SRT-4
        ...Formerly "A853"...
          It's usually $60.
            It's usually $60.
            What requirements are different during non-street legal events?
              You have to pass tech. Battery tie down, overflow, helmet if you're in the 13s, etc.
                Is there a tire requirement?
                  sweet.
                  that means I'll need to change my battery stuff probably. anybody got a link for the 07 rule book(battery relocation in particualar).
                    No there is not a tire rule.
                    Battery relocation to trunk requires an NHRA approved battery box (Moroso blue box is our box of choice), NHRA approved cut off switch, and that the battery box is vented to the outside of the vehicle if it is a hatchback.
                    When you wire the kill switch up, it must kill the vehicle. What this means is the alternator needs to be wired to the battery directly all the way in the rear of the vehicle.
                      K,
                      For how my battery is currently hooked up.
                      I have the original positive cable hooked up to a jumper post. On the back side of the jumper post is where the power wire goes to my battery. So, its like a extension. Would I need to run a seprate wire from the positive of the alternator to the battery?
                      And should the cutoff switch should be in the possitve cable?
                        Correct. The switch needs to be inline on the power side of the battery.
                        Basically it should look like this:
                        BATTERY -------- ALTERNATOR
                        |-------- SWITCH --------------- EVERYTHING ELSE
                          Thanks,
                          Do you think that wired right? Just need to do the approved battery box, with vent, and a approved switch?
                          and recomendations for the switch?
                          this is what I was looking at:
                          http://www.jegs.com/webapp/wcs/stores/servlet/category2_10001_10002_14497_-1
                            I would actually recommend the flaming river switch. It's a push off style switch.
                              thanks :icon_bounce:
                                Oh also, you need to clearly label the switch. If you do the flaming river you need a sticker that says "push off".
                                  I plan on making a bracket that is held in Via closing the hatch so i dont have the switch out all the time. or would this not pass tech?
                                  The car is still driven all the time in the summer, dont want to deal with dumbasses pushing it all the time
                                    Just mount it and don't worry about it. If it doesn't start go pull the switch back out. 😉
                                    The switch has to be permanently mounted.
                                      DAMN. I'll have to figure something out, under the plate or something and take the plate off
                                        wow, no street legals is gonna suck. No street legals=no Dragstrip for me. pretty sad when you can drive to marion and back plus race for only $5 more. This place is so overpriced i would rather go to Brainerd or Marion. Only reason i went in the first place was cause the Tintmasters events brought the price down to a reasonable level. They need to wake up and lower the prices if they want it to stay open.
                                        Gary
                                        • 2wheeler2 Offline
                                          2wheeler2 Offline
                                          2wheeler
                                          Well, unfortunately, not enough people seem to "take care of the people that take care of them".
                                          '08 Suzuki Hayabusa
                                          '09 Yamaha Zuma 200cc
                                          '95 E-350 7.5L
