  3. Track Talk
  4. 2007 Interstate Dragways Street Legals
44 Posts 13 Posters 5.4k Views
    ^I know, its just nice to have a larger number of people, then you can sit and BS with people. Also some people dont want to have to bracket race and loose in the first round. Its nice to be able to go and run. Like at the street legal days.
      So if there is no sponsor there probably won't be any street legal events?
        I don't see them happening, no.
        And who said anything about bracket racing on regular weekends? 🙂
          So what exactly is a "regular" weekend? What kind of racing is it?
            yes, i was under the assumption it was bracket racing, at least when i was there.
              It is but you don't have to partake. I just run test and tune.
                WTF? I honestly didn't know that! That's flippin great!
                • BlueSRT0483B Offline
                  BlueSRT0483
                  So even though bracket racing is going on.... You can still test/tune; what is the costs? I'm assuming obviously more, but w/o the TM street legals, I'm not going to cry over that if test/tune reglar weekends are available.
                  2004 Dodge SRT-4
                  ...Formerly "A853"...
                    It's usually $60.
                      It's usually $60.
                      What requirements are different during non-street legal events?
                        You have to pass tech. Battery tie down, overflow, helmet if you're in the 13s, etc.
                          Is there a tire requirement?
                            sweet.
                            that means I'll need to change my battery stuff probably. anybody got a link for the 07 rule book(battery relocation in particualar).
                              No there is not a tire rule.
                              Battery relocation to trunk requires an NHRA approved battery box (Moroso blue box is our box of choice), NHRA approved cut off switch, and that the battery box is vented to the outside of the vehicle if it is a hatchback.
                              When you wire the kill switch up, it must kill the vehicle. What this means is the alternator needs to be wired to the battery directly all the way in the rear of the vehicle.
                                K,
                                For how my battery is currently hooked up.
                                I have the original positive cable hooked up to a jumper post. On the back side of the jumper post is where the power wire goes to my battery. So, its like a extension. Would I need to run a seprate wire from the positive of the alternator to the battery?
                                And should the cutoff switch should be in the possitve cable?
                                  Correct. The switch needs to be inline on the power side of the battery.
                                  Basically it should look like this:
                                  BATTERY -------- ALTERNATOR
                                  |-------- SWITCH --------------- EVERYTHING ELSE
                                    Thanks,
                                    Do you think that wired right? Just need to do the approved battery box, with vent, and a approved switch?
                                    and recomendations for the switch?
                                    this is what I was looking at:
                                    http://www.jegs.com/webapp/wcs/stores/servlet/category2_10001_10002_14497_-1
                                      I would actually recommend the flaming river switch. It's a push off style switch.
                                        thanks :icon_bounce:
                                          Oh also, you need to clearly label the switch. If you do the flaming river you need a sticker that says "push off".
