  3. Run Your Mouth
  4. Fuck you Microsoft
Fuck you Microsoft
14 Posts 6 Posters 1.4k Views
  • SmitEvoS
    SmitEvoS
    i might have an extra one laying around....you can have it. Unfortunatley I will be out of town this weekend though....
    • MisterCMKM
      MisterCMKM
      You should give it to Jason tomorrow...
      thrash;315544 wrote:
      Ford is back :)
      • K
        K
        A floppy throught the USB wont work? when i redid my old laptop that worked fine.
        • MisterCMKM
          MisterCMKM
          For whatever reason its not working. It could be a shitty external floppy too.
          Ford is back :)
          • Sweet-WRX-LovinS
            Sweet-WRX-LovinS
            Sweet-WRX-Lovin
            WTF? That is gayness. Won't let you download and install or download to a cd or something and install?
            One time...
            • MisterCMKM
              MisterCMKM
              Nope, I could slipstream the drivers into the XP cd, but thats a helluva headache to do.
              Microsoft really dropped the ball on that one.
              Ford is back :)
              • K
                K
                I'll pick up my floppy drive tommarow if I still have it and let you barrow it
                • 9
                  9
                  911LUV
                  MisterCMK wrote:
                  Microsoft, in their infinite wisdom, decided to make it so that you MUST use a floppy drive to load RAID/SCSI/SATA drivers before you can install Windows XP. A USB floppy drive won't work either.
                  I have a floppy drive, but I don't have a frickin cable for it. 😞 Who wants to bring a floppy cable to b-dubs tomorrow?
                  ...did you already toast the drive? And do you have an available computer?
                  If both no...there is a way around it....assuming if and only if...you can get access to the files needed for your SATA/Raid/SCSI card (assuming onboard, if so they came with your mobo)...
                  I wont even go into it unless you answer those questions - if you have another computer, with a CDRW - and have...an hour or two tonight to hammer down. Then I will post a detailed explanation on how to do it....I ran into a lot of issues loading up SBS2k3 on some stupid HP Proliant Servers awhile ago and did not have a floppy drive (fortunately now, there boards have a bootable USB support)
                  • MisterCMKM
                    MisterCMKM
                    Cool. I really just need the cable though.
                    Ford is back :)
                    • MisterCMKM
                      MisterCMKM
                      I just really don't feel like going through the process of slipstreaming the drivers cause I'm a lazy ass. 😄 The floppy drive should still be good as I can read the files from my laptop (its an external floppy). I think that the problem is that my mobo doesn't much care for external floppies or something like that. I want to try my internal drive, but I just don't have a cable for it.
                      Ford is back :)
                      • K
                        K
                        mine is all one. was used as the primary floppy for my old laptop but was external.
                        • integra_gsr98I
                          integra_gsr98I
                          You installed the OS improperly on the HP then. Rule #1 w/ an HP is to start w/ their Smart Start CD and go from there. Conveniently loads in every driver for the system as well as all HP management agents. Easy as fuck.
                          • 9
                            9
                            911LUV
                            Thanks for the tip....Yah I tend to chuck whatever they send me - so anyways - one of the new blades we just got...took my jump drive right off the bat, so that was nice. But I will keep that in mind thanks.
