  4. Talon Dyno Results
Talon Dyno Results
36 Posts 18 Posters 2.9k Views
  • 9 Offline
    9 Offline
    95TsiAWD
    91nbtsi wrote:
    Sweet. What EMS are you using?
    DSMlink. Time to get some colder plugs and tighter gap though.
    95 TSi AWD
    Old Turbo #'s
    522whp/414wtq
    [email protected]
    11.3@129mph
    Procharged 99 Corvette
    95 LS6 Mustang
    01 300m
    06 Suzuki LTR-450
      aliengotpsi
      nice numbers!!! should be a 10 sec car.. that if you got a decent tranny..
      Kevin Smith
      Straightlinedetailing.com
      • capitljC Offline
        capitljC Offline
        capitlj
        Impressive what have you done to the rest of the running gear to make it stand up?
        > Mitch Hedberg wrote:
        2004 Impala LS 3.8
          Running gear. ROTFL>....
            10s car FTW!
            That car will be awsome when it is finaly finished and ready to hit the track
            • 9 Offline
              9 Offline
              95TsiAWD
              97jeep wrote:
              10s car FTW!
              It has been finished for 3 years...
              For the others the car has a shep stage 4 trans.
              95 TSi AWD
              Old Turbo #'s
              522whp/414wtq
              [email protected]
              11.3@129mph
              95 LS6 Mustang
              01 300m
              06 Suzuki LTR-450
                O, I thought I read somewhere about you wanting to swap out that turbo.
                • 9 Offline
                  9 Offline
                  95TsiAWD
                  oh... well yeah I plan to put a BB T67 Ptrim on the car. But it will only be down for 1 hour while I swap it.
                  95 TSi AWD
                  Old Turbo #'s
                  522whp/414wtq
                  [email protected]
                  11.3@129mph
                  95 LS6 Mustang
                  01 300m
                  06 Suzuki LTR-450
                    95TsiAWD wrote:
                    Ptrim on the car
                    weird to me, A P-trim is considered a smallish turbine on a 2 rotor.
                    Piston engines make better use of a turbo of the same size comparisson to a rotary ..... i guess that is why we have turbos the size of the engines, well not me yet 🙂
                    Very nice #'s, i like, How far do you want to run into the 10's?? and was wondering the weight of your car??
                    • 9 Offline
                      9 Offline
                      95TsiAWD
                      T67 Ptrim isnt really a big turbo, but not a small on either.
                      No idea, whatever it runs, it runs. Weight is around 3200 I think, its a pig.
                      95 TSi AWD
                      Old Turbo #'s
                      522whp/414wtq
                      [email protected]
                      11.3@129mph
                      95 LS6 Mustang
                      01 300m
                      06 Suzuki LTR-450
                        What's the weight difference between the AWD and the FWD dsm's?
                        • 91nbtsi9 Offline
                          91nbtsi9 Offline
                          You might be able to click off a high 10 if you get a good 60ft. Just get some C16 and crank your timing up a bit;)
                          • 9 Offline
                            9 Offline
                            95TsiAWD
                            I was able to run the 11.32 on my 470 dynojet whp map in the fall of 05. So high tens should be achievable, its the mid 10's that will be hard.
                            95 TSi AWD
                            Old Turbo #'s
                            522whp/414wtq
                            [email protected]
                            11.3@129mph
                            95 LS6 Mustang
                            01 300m
                            06 Suzuki LTR-450
                            • beachbum_jonB Offline
                              beachbum_jon
                              you should make a trip down to siouxfalls and go to excessive to their awd dyno
                                aliengotpsi
                                I ran 11.2 @ 126-129.5 making 412 wheel Hp @ 25psi this was on a bolt on PTE 50 trim with a stock engine.. stock head gasket too, it's all about the driver if you can shift like you stole it and dont give a fuck about breaking drive train. Id bet your car will run 10's no problem O and some slicks would help alot!!
                                my .02
                                Kevin Smith
                                  Excessive does not have an AWD dyno.
                                    truf
                                      DB performance and LSE performance have AWD loaded dynos
                                      • 94NDTA9 Offline
                                        94NDTA9 Offline
                                        I am envious
                                          beachbum_jon
