  3. Track Talk
  4. Autocross/rally
Autocross/rally
24 Posts 10 Posters 5.1k Views
  • wesholeW
    wesholeW
    Kevin, whatcha got for braking? Tires? Trust me, youll need em. Especially brakes. The stockers will let you down.
    • RidinRailsR
      RidinRailsR
      Stock brembo's should be find as long as you get some good pads and sticky tires.
      • K
        K
        When I get rims I am going to get some RT-615's. Hopefully my kuhmo 711's well do ok. cant beat $42 tires that are somewhat decent
        • wesholeW
          wesholeW
          Exactly what I was getting at. Get some EBC or Hawk pads. You'll thank me later.
          • naturalbornkellerN
            naturalbornkellerN
            naturalbornkeller
            aliengotpsi wrote:
            My evo should do fine on a road course!!!
            JIC FLA-2's full coil overs w/ Stiff Springs
            Chassis Brace
            Trunk full of braces
            Hotchkis Rear Adjustable sway bar
            Aftermarket adjustable front sway bar
            Soon to get End links, and all new bushings
            Anyone know of anyother parts that would help out alot?
            A truck and a trailer is a smart idea. Just in case your car breaks or you crash or whatever, anything can happen. thats the thing that keeps me from doing more roadracing besides my job, just too busy in the summer.
            • ColinC
              ColinC
              Colin
              Chassis Brace
              how quick is your steering rack??
              • A
                A
                aliengotpsi
                Steering is very quick , I also have a very small aftermarket steering wheel that seems to help alot! Wes I plan to do SS brake lines, and hawk pads befor I race.. The only thing I need is someone to set up my suspension and sway bars anyone have a clue? I will also be getting some very very stick tires that may not last long...
                450+ hp be enough? full boost at 4,000 rpms in 3rd/4th..
                Kevin Smith
                Straightlinedetailing.com
                • ColinC
                  ColinC
                  Colin
                  Your suspension/swaybar/brakes should all be adjusted by you for your specific style of driving so i suggest you bring tools to the track and do your workthere. 450 wheel? with supper stiff rear end....are you familiar with the term "power over", even with your computer on wheels!!
                  • A
                    A
                    aliengotpsi
                    Power over???
                    Kevin Smith
                    • K
                      K
                      I won't be able to provide a in depth tech responce. But I believe its when you are corning and the car begins to loose traction do the the HP/TQ the vehicle makes, not from the suspension or the tires. Sort of like drifting(drifting) but that is the first thing that come to my mind
                      • ColinC
                        ColinC
                        Colin
                        mathematically speaking the stiffer your swaybar setup (big bar, solid everything) the more understeer you will create. THIS DOES NOT MEAN LESS GRIP. It actually makes more grip as more of your tire stays in road contact. Anyway the stiffer your rear end the more appt to slide it is. Then you add all that power your making and you'll create the "power over" drifitng effect. think american muslce car movie u turn drift.You don't swerve to start it, but you start to swing out because of the power you ake. So you're going to probably have your back end swinging around A LOT until you get your setup tuned, or just stay that way and learn to drive it like that. The 2 door billion hp evo does.
                        For reference, watch youtube videos of WRC Road Rally footage. you should be able to do those 1 lane uturn that they do.
