  4. what size turbo on your DSM?
13 Posts 11 Posters 716 Views
    i was thinking about this today when i was looking at the turbo chart i posted up. i have an auto trans 1g, and when my 13G melted i put what i had availible on there. Well knowing this was a little big i figured i would try it anyway. Although, on DSMtuners where i frequent, most people say a 50-trim is sufficient if not big for a street car, well heres a comparison:
    20G-60 inducer,52.60mm major, 68.00mm
    turbine, TD06-S inducer, 55.10mm major, 65.00mm
    what i have on there currently
    TO4-E 60 Trim inducer, 58.17mm major, 74.93mm
    T3 stage III inducer, 56.62mm major, 65.00mm
    Anyway what im getting at is that i have something on a bone stock car, except for a 3" exhaust and its quite a bit bigger than a 20G. Thats freakin big for a DSM and i see alot of complaints about spool time with anything bigger than a 16G. Are these people serious or am i just that much more resilient to turbo lag? I mean i even have the stock auto cams (tiny) and no porting of any kind and i have full boost by 4500, and it pulls like a train anywhere over 4000. Currently i am running 11-12 PSi and occasionally hit fuel cut, which is very annoying. I know its too big, and im dropping it to this next week:
    TO4-B S trim inducer-48.36mm, 69.85mm
    Turbine is about a 50mm inducer, 58.6mm major that was specific to Buick GNs. This is more comparable, basically a 16G turbine, and a 18G compressor.
    16G-60 46.5 57.00
    TD05-H 49.00 56.00
    i think my spoolup will move into the 32-3500 range and i hope to be able to hold around 4-6psi on the footbrake. with the 60-trim i can get .25-.5psi on the brake as it only spools to around 2300 on a 3000 stall converter. SO, how big a turbo you have and what are your thoughts on it? is it too laggy? too small? am i crazy? Also i am doing this all with a round 3-bolt housing bolted up to the stock 1G manifold. it was too easy to make this work BTW
    Gary
    • JohnWJ Offline
      JohnWJ Offline
      JohnW
      Im chillin with a ported 14b, eeprom ecu, stock injectors, and 3000gt fuel pump (did have a walbro 190, but it was loud), intake, exhaust etc.. I don't think thats the kind of response you are looking for though 🙂
      90 Civic DX hatch
      D16a6/y8 mini me
        Walbros loud?..... no 🙂
        I have pissed around with gary in that car, and the characteristics of the car are completely backwards of when the 13g was on.
        • blackcherryTSiB Offline
          blackcherryTSi
          i was rollin the 16g back in my dsm dayz
          1995 Honda Civic
            walbros loud?? man i must be wierd cause i dont think they are. you should hear dual intank 255s sometime, then it starts getting loud. I have to step up to the 2 intanks next winter on the buick.
            Anyway you say you had 16G's, how did you like them anyway. thats what im trying to figure out. I have heard alot of comments that a ball bearing 50-trim will outspool a 16G, and make about 20hp more. And yes it is ass backwards, i was able to hold whatever i could with the 13G, and it was out of steam by 4000, now it comes on at 4000 and pulls to around 58-6200, then those tiny cams hold it back.
            I am excited to drive this thing with th full manual 4-speed auto and leaving with aobut 6psi, should run low 13s pretty easy. may also put some meth injection on it and go for 18psi and some 12's
            Gary
            • gszzzzxG Offline
              gszzzzxG Offline
              gszzzzx
              Rockin pte 57 trim
              1990 eagle talon tsi -on goin project
              95 eg honda hatch b-series dd
                slowvo
                I would say the 14b/16gs make boost too fast and you really arent making power at that low of an rpm anyways.
                stay with stock turbo or go with a (smaller) bit turbo. I dont think the 16G really makes much of an difference, there are way too many other variables that affect power
                  tyklein8
                  i roll with the hahn 20g on my 2g. Definately a little laggy, but boost hits hard.
                  95 Eagle Talon TSi AWD...[B]LONG GONE[/B]
                  2008 Honda Civic Si: Razo weighted shift knob, nokya yellow drls, 4500k ddm hids, k&n drop in filter
                  15.38 @ 91.39
                    They aren't that loud even with 2...it just means your car is too quiet...
                      aliengotpsi
                      Well my bros talon rocks a T4 blowzilla 61mm we get 18psi on the stall and boosts very quick, you should get a IPT Stall converter.. theres a guy who went 10.00 with a stock engine stock tranny with shift kit stall, headstuds upgraded turbo fmic injectors,supporting mods..
                      you can spool anything with an auto/stall and if you cant nos can...
                      btw 20g's are old technology, I used to ran a PTE 50 TRIM and i loved it best turbo I ever had but would always smoke and blow up... I then ran a pte scm61 and it was a little big unless you did alot of drag racing/highway pulls.
                      If i was gonna buy a turbo for a daily driven dsm id get:
                      borg wanger s256, Garret gt30r pte bb50 trim
                      Kevin Smith
                      Straightlinedetailing.com
                        I loved my 50 trim as well...spooled quickly and definately had enough pull...
                        • RudeAwakening MotorsportsR Offline
                          holset hx35, great turbo, especially great price.
                          =J-
                          ---->Always One Step Ahead
                            i had the standard big16g evo3 turbo.....it was decent.
