Intake for Evo
yeah intake on turbo cars doesnt do all that much....have the car professionally looked at.
Don't get an intake, just get a high flow filter.
And I highly doubt the intake is causing the problems, probably a vacuum line or solenoid. Either way, have it inspected by a shop, don't trust the internet to fix all your problems. Just have your dad pay the Mitsubishi dealer to have it fixed.
-Eric
boost solenoid=10 dollars...
An intake will help 10-15 hp over stock.. Fuck the drop in filter thats gay. If you over boost there is one of 3 problems
Cut vac line to the wastegate, or hose off. Also could have the vac lines on wrong.
ECU has been re-flashed by a retard..
Boost control is set up wrong or defulty
Im pretty sure I could fix it but id have to charge you!
My .02
O ya I dont work on cars.. good luck..
