  4. Intake for Evo
Intake for Evo
14 Posts 9 Posters 1.5k Views
    your problem is a boost solenoid.... IIRC
    • eveslowE Offline
      eveslowE Offline
      eveslow
      how would you know?
      2003 Mitsubishi Evolution VIII W/ stage 2 slowboyracing short block. Eagle H-Beam Chrome Moly Rods, Ross Racing Forged 8.5:1 Pistons, Clevite 77 Rod Bearings, Clevite 77 Main Bearings, ARP Rod Bolts. everything else pretty much stock. near future GT35R turbo kit
      AKA cleanest Evo in town
        Just out of curiosity, why would it be the intake?
          yeah intake on turbo cars doesnt do all that much....have the car professionally looked at.
            dude, how would an bad intake afftect how much boost you make? You bought a messed up evo and you cant even take anyones advice as to fixing it to get it how it should be.
            • InstigatorI Offline
              InstigatorI Offline
              Instigator
              Don't get an intake, just get a high flow filter.
              And I highly doubt the intake is causing the problems, probably a vacuum line or solenoid. Either way, have it inspected by a shop, don't trust the internet to fix all your problems. Just have your dad pay the Mitsubishi dealer to have it fixed.
              -Eric
              Playtime Performance
              '91 Honda Accord - DD
              '09 Honda Ruckus - Matte Gray
                boost solenoid=10 dollars...
                  yeah u never know it could be a very easy fix. could just be a vacuum line
                    The car held boost just fine...
                      aliengotpsi
                      An intake will help 10-15 hp over stock.. Fuck the drop in filter thats gay. If you over boost there is one of 3 problems
                      1. Cut vac line to the wastegate, or hose off. Also could have the vac lines on wrong.
                      2. ECU has been re-flashed by a retard..
                      3. Boost control is set up wrong or defulty
                      Im pretty sure I could fix it but id have to charge you!
                      My .02
                      O ya I dont work on cars.. good luck..
                      Kevin Smith
                      Straightlinedetailing.com
