5MGE Problems
PSiedTSi wrote:
just because it isn't a 4cyl doesn't mean it can't rev...? 4k isn't bad at all...i bet it reds at 6500...but having half of the oil in it that it should, and that oil being hella old, and more than likely old plugs/wires/dizzy and old gas probably wouldnt be to great.
redline is a 6500... after i get out of my pracs study and the car is moved to my new house ill be tearing it apart and checking out whats going down on the motor... if its really bad in there there is the possibility of a swap... gotta wait to find out
When I had problems with my '83 Supra it always ended up being fuel related. First my fuel pump went out then I later found out why it failed, rust from the fuel tank had clogged a pre-filter in the fuel line about a foot away from the tank just before the fuel pump. Do you know if your fuel pump is in or out of the tank?
have no idea ill find out when i rip it apart after i get out of pracs...
