  3. Wanted Ads
  4. Needed: Very specific bolt
16 Posts 10 Posters 1.7k Views
  • RidinRailsR
    RidinRailsR
    you should be able to order them and return the rest..did you try the other stores like menards, and lowes ect..
    • Turbo5OhT
      Turbo5OhT
      Turbo5Oh
      um its half standard and half metric? or is the length a estimate? any way far as bolt selection goes ive always found scheels hardware has the best selection ive never once had to order something, but i havent been there since they moved so it could be different now
      • ColinC
        ColinC
        Colin
        ^the threaded hole is for a 5mm bolt, the depth i need is about 1/2 in, so the closest thing would be about 15mm right??
        I'll try scheels. I didn't even think of them when i was running around
        • XJHEADX
          XJHEADX
          If like the ones below I can check tomorrow and let you know..
          Do they have any that are longer that you can cut down??
          • M
            M
            moparguy
            check out fastenal. You will have to buy a box of them, but it usually isnt 70 bucks.
            • DaveHD
              DaveHD
              Scheels hardware.
              • F
                F
                fanaticrockford
                Have you tried ace hardware in moorhead? I got some there almost the same exact size awhile ago. They were like a $1.50 each though.
                • GarageAlchemistG
                  GarageAlchemistG
                  GarageAlchemist
                  scheels carries every bolt for a honda at least, ive always found the goofiest ones ever there.
                  97 GTi, 03 KJ
                  • ColinC
                    ColinC
                    Colin
                    I have bolt like that to cut down. those are pretty easy to find in the 1in length. Unfortunately in need/want the recessed head (see shitty MS paint drawing) if i can't find it after scheels ('cause i've been everywhere else) then i'll just start cutting.
                    • XJHEADX
                      XJHEADX
                      I have those, not sure in 5 mm, I'll let ya know later today
                      • ColinC
                        ColinC
                        Colin
                        thank you.
                        • XJHEADX
                          XJHEADX
                          Looks like they are either 8 mm the others are 10-32 threads on them. Try Northern States Supply on monday, they are behind the water tower off I-29 and 12 ave N
                          • bader3245B
                            bader3245B
                            bader3245
                            www.mcmaster.com ...if you cant find it there, it dont exist.
                            2008 Ford F-150 FX4
                            2006 Honda CRF250R
                            2006 Honda CBR1000RR
                            • ColinC
                              ColinC
                              Colin
                              So I went to scheels: I walked in, was taken aback by how "bed,bath,beyondish" it was....Then i got past all of that crap to the actually hardware section. Beautiful. They have everything. I mean it. I'll never bother going anywhere else.
                              • J
                                J
                                Jared Balow
                                I order alot of bolts, screws and such for work and we use fastenal. if you bring what you need or something close and explain it to them they can order. I have never had to order more than needed. Check there website. www.fastenal.com
                                redrex
