  4. Edge EZ Power Programer
6 Posts 4 Posters 707 Views
  • A
    A
    aliengotpsi
    1998.5-2000 Dodge 5.9 Liter Cummins
    Used Looking for $300.00
    Retail 500.00
    EZD1000 - The Power Edge EZ is a direct plug in, no wire taps or splicing, module that optomizes engine performance by monitoring engine RPM, boost pressures and fueling parameters to the individual injectors. By using this information the EZ controls the fueling and timing of the Bosch injection system. The re-calibration of the fuel and timing parameters is done via CAN-BUS communication through both the Dodge computer system and Bosch injection pump in your truck. The limits of the Bosch system and retained by the EZ module, which provides a smooth and reliable power curve. The EZ produces maximum fueling at full boost pressure to attain an additional 65 HP and 185 ft-lbs of torque with a simple 5 minute installation. The EZ plugs into the the ECM data link connector and the MAP sensor connections and your ready for more power immediately. Removal is just as easy for diagnostic servicing purposes. Being fully water tight and mounting under the hood makes the EZ the easiest performance gain available for your Dodge Cummins. Diesel Performance Parts, Inc.
    Kevin Smith
    Straightlinedetailing.com
    • M
      M
      MazdaMP3ShiftR
      bump ----->$250.00
      -kevin
      • SmitEvoS
        SmitEvoS
        bump 245.oo
        • SmitEvoS
          SmitEvoS
          • torbsT
            torbsT
            • SmitEvoS
              SmitEvoS
              bump 235.00
