Still boggin down...
I'd check your boost pressure...i'm guessing you either have a leak, or your WG isn't opening...i remember on an old 1g (not mine) would fuel cut for some reason at 3-4k @ wot...couldnt figure out what it was...hooked up a boost gauge...22psi...needed a new WG bc the one on it wasnt opening...
matt can attest to this happening
torbs;163476 wrote:
I'd check your boost pressure...i'm guessing you either have a leak, or your WG isn't opening...i remember on an old 1g (not mine) would fuel cut for some reason at 3-4k @ wot...couldnt figure out what it was...hooked up a boost gauge...22psi...needed a new WG bc the one on it wasnt opening...matt can attest to this happening
i guess its not a WG because ive had a mechanic look at it and he said it wasent it..and i just put walboro 255 fuel pump in... -
I have kind of been having this same problem too. I think you may need a AFPR. I have a wally 255 on my talon and I have sputterring problems when I'm cruising on interstate or sometimes just when I take off. I know I am running rich because I dont have a AFPR and the 255 flows too much fuel. I have added new plugs and they helped a bit. I hope that helps a little bit.
Also, RidinRails, you should post up on how you fixed this problem. Thanks
torbs;163506 wrote:
what's wrong with a DSM?...unless you own a shop or know somebody that owns one you are pretty much done for...thats what :icon_bounce:well i didnt own a shop, mine ran fine. Its called properly setting up your car. This includes the correct mods and a TUNE.....that is probably their biggest problem. Get a flipping wideband and an AFC and tune your car and you will be fine most of the time. But we got idiots out there throwing mods on and pushing their cars to the limit and blowing shit up because they didnt tune it.....
^^^exaclty....thats the biggest problem with ppl owning dsms'.^^^
SmitEvo;163519 wrote:
well i didnt own a shop, mine ran fine.Your right, you didnt own a shop...but that doesn't mean you didn't have a tight affiliation with one at the time...or a brother that worked at one at the time :p:
hehe just giving you shit brian
...i really heart you in a totally non-homosexual way
biggest problem with a dsm? its a freakin 17 year old car with 180k miles and some moron puts a boost controller on it and hits 13th ave yO.
