  4. Still boggin down...
129 Posts 21 Posters 7.2k Views
  • blindsp1B
    blindsp1B
    blindsp1
    i got new plugs and wires...but i need to hook up my boost gauge...
    New Bike: 08 zx-6r FOR SALE
    05 Yukon
    • blindsp1B
      blindsp1B
      blindsp1
      and the plugs and wires felt like they did nothing
      05 Yukon
      • SlowicaS
        SlowicaS
        Slowica
        tomorrow durring auto hook the genesis up and take it out for a drive. that will tell you if your sensors are acting up, could be the map or maf sensor reading wrong and causing it run really rich. you could also check the duty cycle of your injectors maybe for some reason there maxing out or fouled up. lol dk to much about the DSMs but the gennesis will be able to tell you a lot should be a good start. or you could just sell it to me, i'll even give you 6k :icon_geek:
        • SPANISH-RICES
          SPANISH-RICES
          whats the setup on this car? whats it actually doing? is there a reason to think that the injectors are actually maxing out? if i knew the whole setup i could maybe conjure up some ideas.
          • blindsp1B
            blindsp1B
            blindsp1
            honestly....i dont know what u mean by setup/....im turbo retarded
            05 Yukon
            • SPANISH-RICES
              SPANISH-RICES
              does your vehicle have anything done to it? like after market? or is it all stock?
              • SPANISH-RICES
                SPANISH-RICES
                and what EXACTLY does it do when it bogs? what gear? what rpm? what % throttle? sounds? smells?
                • RidinRailsR
                  RidinRailsR
                  im guess it just stops revving up..like its running rich and spits and sputters correct??...i can fix it if ya want
                  • MisterCMKM
                    MisterCMKM
                    This outta take care of it.
                    thrash;315544 wrote:
                    Ford is back :)
                    • torbsT
                      torbsT
                      I'd check your boost pressure...i'm guessing you either have a leak, or your WG isn't opening...i remember on an old 1g (not mine) would fuel cut for some reason at 3-4k @ wot...couldnt figure out what it was...hooked up a boost gauge...22psi...needed a new WG bc the one on it wasnt opening...
                      matt can attest to this happening
                      • blindsp1B
                        blindsp1B
                        blindsp1
                        gotcha...it usually does it in 2nd and 3rd gear...never 1st...and 2nd is about 1/2 throttle..and it starts around 4 grand.
                        05 Yukon
                        • blindsp1B
                          blindsp1B
                          blindsp1
                          i guess its not a WG because ive had a mechanic look at it and he said it wasent it..and i just put walboro 255 fuel pump in...
                          05 Yukon
                          • blindsp1B
                            blindsp1B
                            blindsp1
                            it doesnt stop revving it...sounds like massive backfire...
                            05 Yukon
                            • PSiedTSiP
                              PSiedTSiP
                              Go full throttle on it. I wouldn't rev it real high with low throttle.
                              spanish-rice;237125 wrote:
                              • 91nbtsi9
                                91nbtsi9
                                Get an AEM:)
                                • SlowicaS
                                  SlowicaS
                                  Slowica
                                  wanna know the real answer?..............it's a DSM :lol:
                                  • SmitEvoS
                                    SmitEvoS
                                    whats wrong with a dsm? If he knew what he was doing actually......
                                    • torbsT
                                      torbsT
                                      what's wrong with a DSM?...unless you own a shop or know somebody that owns one you are pretty much done for...thats what :icon_bounce:
                                      • MisterCMKM
                                        MisterCMKM
                                        Were you dropped when you were a baby torbs? Did you eat paint chips? Did your mom drink when she was pregnant with you?
                                        Ford is back :)
                                        • T
                                          T
                                          tyklein8
                                          I have kind of been having this same problem too. I think you may need a AFPR. I have a wally 255 on my talon and I have sputterring problems when I'm cruising on interstate or sometimes just when I take off. I know I am running rich because I dont have a AFPR and the 255 flows too much fuel. I have added new plugs and they helped a bit. I hope that helps a little bit.
                                          Also, RidinRails, you should post up on how you fixed this problem. Thanks
                                          95 Eagle Talon TSi AWD...[B]LONG GONE[/B]
                                          2008 Honda Civic Si: Razo weighted shift knob, nokya yellow drls, 4500k ddm hids, k&n drop in filter
                                          15.38 @ 91.39
