  4. coolant
coolant
29 Posts 12 Posters 1.1k Views
    I would only do it in case of emergency. I can not remember why you are not suppose to do it, but IIRC its a pretty good reason. You can run all water in your car, you just have to worry about it rusting and having a higher freezing point.
      You don't want to run all water as the boiling point is around 212 degrees. Ethylene-Glycol increases the boiling point when mixed with water. It also prevents corrosion, heat transfer and lowers the freezing point.
          That isn't going to make much of a difference at all
              Its coolant we're talking about here not motor oil...
                yeah, your right...the only thing coolant is really for is to keep the temperatures lower and keep the water from boiling away
                  All I am saying is that the extra viscosity of straight antifreeze over a 50/50 mix is never going to make a difference.
                    yes i know...i am agreeing.
                      CMK for post whore of the night!
                      You also forget that adding pressure to the system raises the boiling point. 3 degrees for every PSI
                        You're fucking right. I am taking back my title.
                        • BookemB Offline
                          BookemB Offline
                          Bookem
                          I've seen tons of stock water pumps take a dump after long term use of 75% or more coolant mix. I would avoid if possible.
                          Legacy GT
                          Gmc Suburban
                          Hallorann: Fargostreet?
                          Hallorann: No, I ain't.
                            Antifreeze/coolant does not do it's job as well nor as efficiently when used by itself just like water doesnt do as good straight either. I'd use either alone only temporarily.
                            • ColinC Offline
                              ColinC Offline
                              Colin
                              I think that i read somewhere that straight antifreeze works better for heat transfer, but is like a "racing only" brake pad. You have to get it all heated up, then drive the piss out of it, then flush the system. Oh, and it's harder on your engine for some reason.
                                im sure the viscosity of straight coolant compared to straight water is quite a bit different. Running striahgt coolant would definitly bring your boiling point up, but who wouldwanna run that hot anyways. just buy 50/50.
                                • beachbum_jonB Offline
                                  beachbum_jon
                                  yeah thats what i thought, but i just wanted to know cuz i was in a pinch the other day where a coolant hose came off and all i had was coolant so i just did straight coolant.
                                  -John Adams, 1735-1826-
                                  • killer69penguinK Offline
                                    killer69penguin
                                    yes people should just not be cheap and buy it 50 50 to begin with in my book, but i guess if you wnat to save a few bucks do what works best for you
                                    1993 3000GT VR4
                                      Why in the fuck would you buy it 50/50? You are paying the same price, if not more for half of the coolant mixed with water.,
                                      • ticklemedalyT Offline
                                        ticklemedaly
                                        your paying for 100% distilled water mixed with it, which is what is to be used in your coolant system. Although, depending on the manufacture (chrysler specifically), the coolant comes straight 100% coolant....yet Honda is 50/50 mixed.
                                        XBL G-tag: TickleMeDaly83
                                          Meh, I'd rather buy my 100% coolant for the same price and spend a dollar on a gallon of distilled water. Either way, pre-mix is a big fucking ripoff.
