  4. coolant
coolant
29 Posts 12 Posters 1.1k Views
      That isn't going to make much of a difference at all
          Its coolant we're talking about here not motor oil...
            yeah, your right...the only thing coolant is really for is to keep the temperatures lower and keep the water from boiling away
              All I am saying is that the extra viscosity of straight antifreeze over a 50/50 mix is never going to make a difference.
                yes i know...i am agreeing.
                  CMK for post whore of the night!
                  You also forget that adding pressure to the system raises the boiling point. 3 degrees for every PSI
                    You're fucking right. I am taking back my title.
                    • BookemB Offline
                      BookemB Offline
                      Bookem
                      I've seen tons of stock water pumps take a dump after long term use of 75% or more coolant mix. I would avoid if possible.
                      Legacy GT
                      Gmc Suburban
                      Hallorann: Fargostreet?
                      Hallorann: No, I ain't.
                        Antifreeze/coolant does not do it's job as well nor as efficiently when used by itself just like water doesnt do as good straight either. I'd use either alone only temporarily.
                        • ColinC Offline
                          ColinC Offline
                          Colin
                          I think that i read somewhere that straight antifreeze works better for heat transfer, but is like a "racing only" brake pad. You have to get it all heated up, then drive the piss out of it, then flush the system. Oh, and it's harder on your engine for some reason.
                            im sure the viscosity of straight coolant compared to straight water is quite a bit different. Running striahgt coolant would definitly bring your boiling point up, but who wouldwanna run that hot anyways. just buy 50/50.
                            • beachbum_jonB Offline
                              beachbum_jon
                              yeah thats what i thought, but i just wanted to know cuz i was in a pinch the other day where a coolant hose came off and all i had was coolant so i just did straight coolant.
                              -John Adams, 1735-1826-
                              • killer69penguinK Offline
                                killer69penguin
                                yes people should just not be cheap and buy it 50 50 to begin with in my book, but i guess if you wnat to save a few bucks do what works best for you
                                1993 3000GT VR4
                                  Why in the fuck would you buy it 50/50? You are paying the same price, if not more for half of the coolant mixed with water.,
                                  • ticklemedalyT Offline
                                    ticklemedaly
                                    your paying for 100% distilled water mixed with it, which is what is to be used in your coolant system. Although, depending on the manufacture (chrysler specifically), the coolant comes straight 100% coolant....yet Honda is 50/50 mixed.
                                    XBL G-tag: TickleMeDaly83
                                      Meh, I'd rather buy my 100% coolant for the same price and spend a dollar on a gallon of distilled water. Either way, pre-mix is a big fucking ripoff.
                                        killer69penguin
                                        yes i agree with you that paying the same price seems a little rediculious, but at the same time its not like its expensive and is a lot more handy to have it already mixed when you need it
                                        1993 3000GT VR4
                                          ticklemedaly
                                          exactly. in a case like this, the convienience out weighs the cost factor a lot. Only thing reason why you would need pure antifreeze is if you have an application that requires it, or you have massive leaks to where you go through it constantly....which in that case, get the damn leak(s) fixed and stop polluting. I dont wanna be drinking your antifreeze in my tap water.
