  3. Wanted Ads
  4. WTB: Z32 MAF (n62) and SR20DET injectors x6
12 Posts 5 Posters 936 Views
  • ColinC Offline
    ColinC Offline
    Colin
    As stated, I would like to see if anyone local has this stuff
    thanks
      Nobody around hear has that. Your best bet would be to go on zilvia.net or d-town.us.
      the maf well go for around 110-125 shipped. and the injecotors are ussaul the same price for a set of 4.
      • ColinC Offline
        ColinC Offline
        Colin
        kinda what I figured, thought I'd try local first
          yup. this is for your subaru I assume? if so curious on your choice of nissan parts
            They both use side-feed injectors...not sure about the MAF tho.
            • ColinC Offline
              ColinC Offline
              Colin
              Raising redline means need more air. More air means more fuel. More air also means need more accurate reading on incoming air. Especially when you're shooting for 8K in a subaru
                but how will you adapt a nissan Mass air flow sensor to a subaru.
                • ColinC Offline
                  ColinC Offline
                  Colin
                  they have this tool called a drill. then you use these things call bolts in combination with this other thing called a nut.
                    washers?
                    • ColinC Offline
                      ColinC Offline
                      Colin
                      Ah yes! the indominatable washers. Also silicone caulk.
                        why not just wire it to work? or are u wanting just the little thing that does the reading and adapting that into the subaru maf?
                        • ColinC Offline
                          ColinC Offline
                          Colin
                          I am just wiring it in. the drill is for my stock air tubing, the wiring is compatable with stock. Then it's one rom chip and the bigger injectors. done.
