  3. Run Your Mouth
  4. Rusty Bolts FTW!!!!
Rusty Bolts FTW!!!!
32 Posts 15 Posters 2.9k Views
    do they use those bolts as a way to adjust camber on hondas? if so, you should probably get the right one.
    my car is 17 years old, and i have never snapped a bolt of on it.
      This is common and shitty. If I had a extra set I would hook a brother up!
      Any bolt will work but make sure it's grade 10, otherwise you might break it..
      • Afsil80A Offline
        Afsil80A Offline
        Afsil80
        Ditto, except for a bolt on the heat shield when I was pulling the KA out.
        -Peter
        1991 240SX
        • darkelvisD Offline
          darkelvisD Offline
          darkelvis
          those grooves are to keep the bolt from spinning, but, most of the ones I see at the shop were previously fucked by another mechanic who reefed the hell out of them and spun the grooves smooth. 🙂 just go buy some a macs. 🙂
          • thurmanmermanT Offline
            thurmanmerman
            They aren't going to back out at all are they?
            > Parker;299126 wrote:
              DelSlow;174497 wrote:
              i think i have some, ordered them from honda, there like 18 bucks a piece. ..
              well if you have some then there mine. as you still owe me a few... bastered
                thurmanmerman
                I am FUCKED! Well I broke of the head of the bolt that goes through a threaded nut thats WELDED to the shock! Is there a safe way I can drill out the bolt? I was thinking I could jack the rear end up, take the wheel off and jack up the suspension and then drill it out but will that work without messing something up?
                • GarageAlchemistG Offline
                  GarageAlchemist
                  They have the exact bolts that fit at the scheels on Uni, they fit like they were made for the car. Ive bought a few there.
                  97 GTi, 03 KJ
                    and by few you mean one.
                      I did that to one of my old cars. Just get a drill un in there and start drilling right through the bolt. I did it and it came out fine.
                        thurmanmerman
                        As of 2 minutes ago make that 2 bolts I have to replace. Never realized how hard it is to work on older cars. My toyota wasn't even this bad!!
                          it's a honda/rust thing...
                            Welcome to cheap import metal...
                              +1 on what tjamz and cmk said. Hondas = rust
                              • Cura86C Offline
                                Cura86C Offline
                                Cura86
                                yeah hondas are bad for that. Its hard enough to keep it off the body.
                                www.RoadsideSalvage.com
                                • BlackEJ8B Offline
                                  BlackEJ8B Offline
                                  BlackEJ8
                                  Expletive Honda's shitty suspension peices. I am in the process of replacing the axles on my car and I have to replace a few nuts that are rusted to hell. Even worse is mac's doesnt have the right size castle nuts I needed. Now I am waiting for Corwin to order the damn nuts as I sit here car-less and pissed off.
                                  Honda Civic Si - Daily
                                    ^ you probably could have gotten them at a parts store...I know we have a bunch of different ones.
                                      thurmanmerman
                                      Who do you mean by we?
                                      • BlackEJ8B Offline
                                        BlackEJ8B Offline
                                        BlackEJ8
                                        I checked a few of the places and they said they didnt have any, and I didnt feel like getting a whole new balljoint assembly. And who is this we that you speak of?
                                          I work at Autozone....
