  3. Run Your Mouth
  4. Rusty Bolts FTW!!!!
Rusty Bolts FTW!!!!
32 Posts 15 Posters 2.9k Views
  • thurmanmermanT Offline
    thurmanmerman
    DelSlow;174489 wrote:
    you have to buy the acctual bolt...unless your ghetto...so go to Macs..
    I kinda car but I kinda don't. Its rusted and prolly won't be driven more than a year or 2. Where can i find the bolts?
    > Parker;299126 wrote:
      i think i have some, ordered them from honda, there like 18 bucks a piece. ..
        What do u expect from a car that's over 15 years old, most cars i've worked on that are that old are like that, especially if they've been driven all year round.
          thurmanmerman
          Yuck! Thats half the cost of my springs. It may be worth it tho.
            Im sure i have a set or 2 laying around, but f-it just go and get some at macs, who cares??
              thurmanmerman
              Does it really matter if they are grooved or not?
                do they use those bolts as a way to adjust camber on hondas? if so, you should probably get the right one.
                my car is 17 years old, and i have never snapped a bolt of on it.
                  This is common and shitty. If I had a extra set I would hook a brother up!
                  Any bolt will work but make sure it's grade 10, otherwise you might break it..
                  • Afsil80A Offline
                    Afsil80A Offline
                    Afsil80
                    Ditto, except for a bolt on the heat shield when I was pulling the KA out.
                    -Peter
                    1991 240SX
                    • darkelvisD Offline
                      darkelvisD Offline
                      darkelvis
                      those grooves are to keep the bolt from spinning, but, most of the ones I see at the shop were previously fucked by another mechanic who reefed the hell out of them and spun the grooves smooth. 🙂 just go buy some a macs. 🙂
                        thurmanmerman
                        They aren't going to back out at all are they?
                          well if you have some then there mine. as you still owe me a few... bastered
                            thurmanmerman
                            I am FUCKED! Well I broke of the head of the bolt that goes through a threaded nut thats WELDED to the shock! Is there a safe way I can drill out the bolt? I was thinking I could jack the rear end up, take the wheel off and jack up the suspension and then drill it out but will that work without messing something up?
                            • GarageAlchemistG Offline
                              GarageAlchemist
                              They have the exact bolts that fit at the scheels on Uni, they fit like they were made for the car. Ive bought a few there.
                              97 GTi, 03 KJ
                                and by few you mean one.
                                  I did that to one of my old cars. Just get a drill un in there and start drilling right through the bolt. I did it and it came out fine.
                                    thurmanmerman
                                    As of 2 minutes ago make that 2 bolts I have to replace. Never realized how hard it is to work on older cars. My toyota wasn't even this bad!!
                                      it's a honda/rust thing...
                                        Welcome to cheap import metal...
                                          +1 on what tjamz and cmk said. Hondas = rust
