  4. just bought a hatch
just bought a hatch
25 Posts 8 Posters 2.0k Views
    nice man!...personally though...if you boost it, a mini-me won't really do you any good. the A6 is a very sturdy motor stock...basically, the bottom end will give out before you out-flow the head (stock heads are good for well over 300whp, which a stock bottom end cant really get you to)...basically you'll save yourself some money and time if you dont do it...just keep what ya got, but obviously do a multi-point swap...
    btw...where the hell did you find a dp A6?...somebody musta needed a motor and just had an A6 laying around or something...
    nice man tho!!! fun/cheap project
      interested in trading yours+cash for an EG hatch??
        svxAL;178953 wrote:
        i just picked up a 90 ef hatch for $200 dollars. it has no honda rust and just needs a hood and two front fenders. dont have to get them bt there pretty dinged up. the motor is a d16A6 with dual point fuel injection.and needs a head gasket. im a huge noob to hondas but spanish rice is going to help me out with this.
        plans mini me swap then boost. pics will be up tommorow
        Umm...u sure it's an A6 with DP, cuz whoever did that must have been stupid, If you take the effort of putting an A6 in at least swap it to multi-port or something, almost as bad as a guy on the crx forums wanting to put at D15B2 Dp into a teg. But anyways decent buy.
        • svxALS Offline
          svxALS Offline
          svxAL
          yes im sure it said it on the block and its a dual point feul injection says that to lol
          94 Subaru SVX FWD
          subaru-svx.net
          1999 silverado
            yea im pretty pumped about this project. for 200 bucks i think he scored a pretty damn good deal. literally no rust. BUDGET BOOST ROUND 2!
            • svxALS Offline
              svxALS Offline
              svxAL
              yea maby i will just do the multi point swap then boost. but the motor from what the guy told me is stock for this car nothing has been done to it found it in north moorhead
              94 Subaru SVX FWD
              subaru-svx.net
              1999 silverado
                IIRC the A6 never came with DPFI, if you want a MPFI manifold, let me know and you can have one for free.
                • svxALS Offline
                  svxALS Offline
                  svxAL
                  yea for sure i will pm u my #
                  94 Subaru SVX FWD
                  subaru-svx.net
                  1999 silverado
                    A6 never did come with Dp, I believe the DPFI engine is a D15B2. What trim package is your hatch. I'm guessing it's a Dx that someone swapped an Si engine into and was too lazy to convert to mpfi and used the DP head, beings it's the only one to come with it, the STD and SI's had mpfi. I'd suggest doing a mpfi swap, Dual-points are pretty much worthless, and probably a mini-me. If u wanna do something really sweet read this month's Honda-Tuning. They do a sick D16A6 stroker build using D17 internals...cept it has 13.2 to 1 compression, but put out 165hp and 135tq which is crazy for a N/A D16 non-vtec.
                      Oh I also have a jdm DOHC ZC (D series) swap i'd like to get rid of, all u have to do is convert to mpfi and it'll bolt right in, lmk if u'd be interested.
                        i think he would rather keep it simple and just boost till it blows. hes not really in the market to swap anything but the DP to MP.
                        • svxALS Offline
                          svxALS Offline
                          svxAL
                          does anyone have any cheap turbo parts like manifolds or a turbo lines wastegate etc. ???
                          94 Subaru SVX FWD
                          subaru-svx.net
                          1999 silverado
                            i have a t25 mini-log manifold i could sell $200 for internal wastegate
                              lol AL youre so excited to start this. if youre lookin for cheap turbo parts the WTB section is where you wanna be. lets figure out what you're gonna need first tho.
                                you still got that thing? we might have to take a looksee at that tonight.
                                  bubba;179057 wrote:
                                  A6 never did come with Dp, I believe the DPFI engine is a D15B2. What trim package is your hatch. I'm guessing it's a Dx that someone swapped an Si engine into and was too lazy to convert to Multi-port and used the DP head, beings it's the only one to come with it, the STD and SI's had Multi-port. I'd suggest doing a multi-port swap, Dual-points are pretty much worthless, and probably a mini-me. If u wanna do something really sweet read this month's Honda-Tuning. They do a sick D16A6 stroker build using D17 internals...cept it has 13.2 to 1 compression, but put out 165hp and 135tq which is crazy for a N/A D16 non-vtec.
                                  multi-port!?!? lawlz!!!! zomg...sounds like somebody has watched the fast and the furious a few times too much...
                                  yes...fully build a non-streetable d-series only to make the same power as a stock GSR...that makes total sense...if it was actually streetable that'd be different...but 13.2:1...fuck that shat.
                                    Well building a D-series for N/A is retarded, boost is the only way to go......
                                    • svxALS Offline
                                      svxALS Offline
                                      svxAL
                                      thanks for the multipoint intake manifold inspector01
                                      94 Subaru SVX FWD
                                      subaru-svx.net
                                      1999 silverado
                                        Not a problem, at least it will go to good use on your car rather than sitting around collecting dust.
                                          shut up Torbs, when do u want me to take a picture of the B16A7 block since according to you that doesnt exist...
