fs b18a1 motor and trans
Up for sale is a b18a1 motor trans ecu. No injectors, alternator axles intermediate shaft or distributor or harness as im using all this to put my swap in how ever the obd1 stuff from my swap could possibly go with it. Motor is still in the car it has 158k on it was went through about a year ago rebuilt the head timing belt water pump head gasket ect. Compression is 195psi across the board the transmission has no grinds or pop outs clutch could be replaced feels a little weak but wouldn’t have to be. I will be posting up pics tomorrow of motor and compression test. Like I said motor is still in the car if you want to listen to it run or drive it. Asking $600 obo ryan 701-317-0455
quit busting his balls, this is a damn clean and well maintained motor. I can vouch for it.
how much would u want for just tranny?
