  4. fs b18a1 motor and trans
11 Posts 6 Posters 789 Views
  • g2gsG Offline
    g2gsG Offline
    g2gs
    Up for sale is a b18a1 motor trans ecu. No injectors, alternator axles intermediate shaft or distributor or harness as im using all this to put my swap in how ever the obd1 stuff from my swap could possibly go with it. Motor is still in the car it has 158k on it was went through about a year ago rebuilt the head timing belt water pump head gasket ect. Compression is 195psi across the board the transmission has no grinds or pop outs clutch could be replaced feels a little weak but wouldn’t have to be. I will be posting up pics tomorrow of motor and compression test. Like I said motor is still in the car if you want to listen to it run or drive it. Asking $600 obo ryan 701-317-0455
      • g2gsG Offline
        g2gsG Offline
        g2gs
          • g2gsG Offline
            g2gsG Offline
            g2gs
            i am willing to split the motor and trans as well
              • g2gsG Offline
                g2gsG Offline
                g2gs
                best reasonable offer then i want it sold! i will remember that when you post up threads
                  quit busting his balls, this is a damn clean and well maintained motor. I can vouch for it.
                    so im supposing that it's a cable trans?...or is it hydro?...asking bc you mentioned obd1 in the ad
                    • W Offline
                      W Offline
                      wo1fpack2004
                      how much would u want for just tranny?
                      • g2gsG Offline
                        g2gsG Offline
                        g2gs
                        yes its cable im thinking that everything will go with but the axles and alternator but might throw in the one that comes with my swap
