  4. My DSM is friggen slow. Any thoughts?
71 Posts 19 Posters 2.4k Views
  • 3_Series3 Offline
    3_Series3 Offline
    3_Series
    Don't know if they would help too much, but you could try investing in some iridium plugs (Denso, NGK) for better spark. They're supposed to be particularly beneficial for forced induction applications.
    2002 Subaru Legacy
    1993 BMW 325i (sold)
      Based on what you have as far as mods go (very modest), you may be able to net a high 13 sec pass at best. It may be nothing more than launch/ driving technique. Launch alone can do alot for cutting time off your e.t.
      • JohnWJ Offline
        JohnWJ Offline
        JohnW
        No wideband, basically what I'm going off of (using guides from the interwebs) is logs of o2 sensor voltage and knock counts at rpms. Thats what most people use when using this setup as I understand (eeprom ecu, palm logger w/ mmcd). I do the actual editing using evilscribe with a template kind of thing for 1g dsm so I'm pretty sure I'm tuning in the right spots. The thing is though, without a wideband or dyno, just a 3rd gear pull, and with the slow sample rate of the palm, the tune ends up very rough.
        90 Civic DX hatch
        D16a6/y8 mini me
          Also, what octane fuel are you using?
          • TsiTomT Offline
            TsiTomT Offline
            TsiTom
            JohnW;181369 wrote:
            spun steel cat
            Is it still a cat or a test pipe? (that may be choking some airflow)
            I would also get rid of that mas for a 2nd gen...even upgrade the injectors...
            Do you still have stock IC piping?
            Tom Opgrand
            2011 Camry
            • JohnWJ Offline
              JohnWJ Offline
              JohnW
              That could be it, I was unable to avoid the water box as doing so would have involved going into the median and knocking over a bunch of stuff, so I did actually get some wheel spin at the launch.
              I was launching at around 4k as I am still on a stock clutch as I haven't changed out my tranny yet for one with working 2nd gear syncros. I've got an ACT 2600 sitting in the garage tho.
              90 Civic DX hatch
              D16a6/y8 mini me
                That would entail getting an AFC or other form of fuel controller.
                • JohnWJ Offline
                  JohnWJ Offline
                  JohnW
                  its a high flow cat with a metal core instead of ceramic. its basically the least restrictive you can get without a test pipe.
                  I am planning on doing that, trying to save up for a few mods here next month.
                  yep, sure do.
                  also im running 91 octane
                  90 Civic DX hatch
                  D16a6/y8 mini me
                    JohnW;181369 wrote:
                    BTW who all lives in amber valley, I see a ton of nice cars out there, I'm sure you've seen the green machine out front by amber crossing.
                    i see it, and hear it...belt squealing !! haha i always see a girl driving it though...or i think so anyways.
                    Yeah thers lots of nice cars there though, 2 evo's, 2 sti's, nice older 2.5rs..ect.
                    • JohnWJ Offline
                      JohnWJ Offline
                      JohnW
                      I could run a 2g mas w/o an afc, just needs a few lines of code in the ecu to compensate.
                      90 Civic DX hatch
                      D16a6/y8 mini me
                      • TsiTomT Offline
                        TsiTomT Offline
                        TsiTom
                        Ive only read a little bit about that program...but cant you compensate for larger injectors as well?....
                        Tom Opgrand
                        2011 Camry
                        • JohnWJ Offline
                          JohnWJ Offline
                          JohnW
                          My wife drives it since our other car isn't working right now. And the belt does suck. 🙂
                          90 Civic DX hatch
                          D16a6/y8 mini me
                          • D S ohMD Offline
                            D S ohMD Offline
                            D S ohM
                            If you are going to do a 2g mas, make sure you upgrade to 550s. Buy an AFC at the same time. If you dont want to spend 300 bucks on a wideband, take it to Tintmasters and have them tune it on theirs.
                            I wanna go fast!
                            • JohnWJ Offline
                              JohnWJ Offline
                              JohnW
                              Yep, you sure can, you can also do a stutter box, take out fuel cut, reset knock counts, and actually make the range of tuning wider.
                              I have a heavily moddified ecu program waiting to go in but im scurred cuz I'm not sure if I did everything right 🙂
                              90 Civic DX hatch
                              D16a6/y8 mini me
                              • D S ohMD Offline
                                D S ohMD Offline
                                D S ohM
                                Chipped ECUs are the shit. Im hoping to get one over the winter while my car is down.
                                I wanna go fast!
                                • JohnWJ Offline
                                  JohnWJ Offline
                                  JohnW
                                  Im hoping to get a cheap FMIC setup, injectors, 2g mas, and a dsmlink setup coming up here next month.
                                  90 Civic DX hatch
                                  D16a6/y8 mini me
                                    ngk brp7es or brp6es is all you need, dont spend money on expensive plugs....
                                    • D S ohMD Offline
                                      D S ohMD Offline
                                      D S ohM
                                      DSMlink is awesome if you have the extra money to spend on it. Way better than an AFC. Good choice.
                                      Well put. All you really need is some cheap NGK plugs. .028-.029 gap.
                                      I wanna go fast!
                                      • JohnWJ Offline
                                        JohnWJ Offline
                                        JohnW
                                        [QUOTE=D S ohM;181395]DSMlink is awesome if you have the extra money to spend on it. Way better than an AFC. Good choice.
                                        Ya, I figure since I already have some experience tuning with logs on a computer I should be able to use DSMlink fairly easily. My ecu is already socketed besides. It is expensive but if you remember how many ppls afcs get stolen around here, it evens out dont you think?
                                        90 Civic DX hatch
                                        D16a6/y8 mini me
                                        • JohnWJ Offline
                                          JohnWJ Offline
                                          JohnW
                                          Well, hopefully I'll see some ppl at the track and decide to be social. Maybe you guys can give me some tips on driving and whatnot.
                                          90 Civic DX hatch
                                          D16a6/y8 mini me
