  4. civic clutch issue
civic clutch issue
15 Posts 11 Posters 919 Views
  • C Offline
    C Offline
    crzyej6
    i recently bought my 99 honda civic hatback with a b16 swap and it also has an exedy stage 2 clutch in it... but today i noticed that if crusin at 35mph in 4th gear and i give it like half or a little more gas, it just revs up from that speed but it catches fine when i shift and it only slips when its already in gear (from what i know) . The guy i bought it from said it should be fine but sumtin needs to be tuned or tightened or sumtin, So is it going out or do i need to bring it some where to get fixed?
    • Gundar1G Offline
      Gundar1G Offline
      Gundar1
      • blindsp1B Offline
        blindsp1B Offline
        blindsp1
        tintmaster's will help ya
        New Bike: 08 zx-6r FOR SALE
        05 Yukon
          bleed the clutch/slave...if that doesn't work then you prolly need a new clutch...if you dont know how to do it you can go ahead and pm your number and we can get together and bleed it...it takes like 5 min...lmk
            It's a hydro clutch so you can't really adjust it try bleeding it for sure.
            If you need a new one installed shoot me a PM, I will do it pretty cheap.
              uh...yes you can..
                the only thing you can adjust on a hyrdraulic clutch is pedal play. this might help him too tho.
                • L Offline
                  L Offline
                  luvmy92gmc
                  it's probably clutch slippage unless the car was an automatic to start with... usually the pedal play doesn't get tampered with much, clutches are cheap anyways
                  • BassplayerB Offline
                    BassplayerB Offline
                    Bassplayer
                    Brandon it's one of two things. Either the clutch is shot or the clutch is shot. Theres also the possible the previous owner put it on the wrong way...
                    1995 GMC Sierra
                      Why would it being converted to manual cause the clutch to slip?? And clutches really aren't that cheap, and they are kind of a pain in the ass to install with the motor in the car.
                      • L Offline
                        L Offline
                        luvmy92gmc
                        converting a car would have nothing to do with the clutch slippage but you obviously need a clutch pedal for a manual vehicle....and I was replying to the guy that said the pedal might need adjusting because whoever put in the pedal assembly might not have adjusted it.....and i also have a 2 post lift in my garage so it's never really been that hard to do clutches in anything
                        • D S ohMD Offline
                          D S ohMD Offline
                          D S ohM
                          It was a 5 speed from the factory, and clutches do suck when the motor is in the vehicle.
                          I wanna go fast!
                          • L Offline
                            L Offline
                            luvmy92gmc
                            pulling the tranny sucks period....especially when it's an auto like the one i put in my honda hatch a few weeks ago, thing weighs about as much as a 350 turbo i'd say
                              So you said that changing a clutch has never really hard, but pulling the tranny sucks, how do you change the clutch without pulling the tranny?? And yes, honda autos are very heavy, but not really any worse to swap then manuals.
                              • L Offline
                                L Offline
                                luvmy92gmc
                                it's not hard i just hate doing it.... i suppose i contradicted myself a little bit when i said clutches are never really that hard but trannys are always a bitch.... so i can see why you'd be a little confused.... but usually when i think tranny im thinking automatic...and well i've never liked dealing with those much at all, manuals are lighter, smaller much easier to work with....it still only took me about 3 hours to replace the tranny in my civic and it wasn't hard at all.....so a manual being smaller and lighter once you resurface the flywheel put the clutch on the flywheel and put the tranny in....shouldn't really take that long, it's not hard at all.....but i still hate doing it with all that asbestos crap and the fact my old tranny had a huge hole in it so i was covered in atf all while putting the new used one in
