  4. 91 civic fueling issues
11 Posts 6 Posters 667 Views
  • ColinC Offline
    ColinC Offline
    Colin
    So i bought a gay honda, the wrecked one from DL. It ran fine, trailered it, brought it back, ran, took out the Stereo, speaker, overhead lights, and cut the seat belt monitor. now the fuel pump is not working. Its electronic carbed, and fires if i throw starter fluid down into it. Need some honda guys thoughts or suggestions.
    • gsrEKG Offline
      gsrEKG Offline
      gsrEK
      try a new main relay
      2009 Yamaha Zuma 125, gas HOG
      2008 Honda Fit daily
      A s2k
      1991 Honda civic DX Mint SOLD
      1988 Mitsubishi Mighty max
      > BlackEJ8;233529 wrote:
      • GhettoFabulousCRXG Offline
        GhettoFabulousCRX
        Well it's dual point fuel injection I'm guessing? Like he said try a main relay from someone elses 88-91 civic. That's usually the problem. It was hot today sometimes they will act up when it's hot. If I remember right the problem was cracking in the solder or something like that.
        1993 Nissan 300ZX- Twin Turbo
        1995 civic CX
        2006 Honda CRF50
        1987 Yamaha Ysr-50
        1995 Acura Integra sold
        7 EF civic or crxs sold
          if all else fails colin, talk to Kyle
          • ColinC Offline
            ColinC Offline
            Colin
            I called him today (if bryce gave me the right number and my stupid fat fingers didn't fuck it up) we'll see.
            • L Offline
              L Offline
              luvmy92gmc
              i think those fuel pumps are right underneath the rear seat, you can always hook it up to a 12v power source to see if its working, or you might have accidentally taken out the wiring for it like a ground or something it needs to function, if thats the case the sending unit prolly isn't going to work either and the gauge in your cluster will be off, if it does end up being that you can always just run a few wires from ignition and battery back to your pump
              • ColinC Offline
                ColinC Offline
                Colin
                It took me two trips to bring the right relay, but kyle did some 3 minute magic and the car run fine. Well as fine as any carbed honda with 260k on the clock runs.
                  GhettoFabulousCRX
                  BTW it's not carbed it's dual point fuel injection
                  1995 civic CX
                  2006 Honda CRF50
                  1987 Yamaha Ysr-50
                  • L Offline
                    L Offline
                    luvmy92gmc
                    i'm not much of a honda person myself.... but isn't dual point just honda's way of saying throttle body injection? which could easily be mistaken for an "electronic carb" cuz that's pretty much what it is being it replaces everything except the throttle blade and the body and just puts an injector right on top in the middle of the bore?
                      yes you are correct....^^^
                      • ColinC Offline
                        ColinC Offline
                        Colin
                        I like to think of it as a carb. so I will continue to do so. for the 2 weeks before the motor blows up.
