  4. missing cam
missing cam
64 Posts 25 Posters 8.9k Views
  • MisterCMKM
    MisterCMKM
    Still have polishing left to do on the valve covers.
    thrash;315544 wrote:
    Ford is back :)
    • T
      T
      thrash
      this is the 4.6 engine right? is it 100% metric hardware now ?
      • XJHEADX
        XJHEADX
        4.6 not until 96'
        about 1/3 of the 302 shit is metric, pain in the ass
        • MisterCMKM
          MisterCMKM
          The motor is almost all standard but then the body is metric. Fucking clusterfuck. haha
          Ford is back :)
          • N
            N
            Ngige
            MisterCMK;185561 wrote:
            Yup, they have that little pinch in them.
            I have both heads off and the pistons/block surface cleaned up and ready for the heads. I am working on tapping the block holes and will probably bolt the heads on tonight. Fucking autozone shit taps breaking off blow ass BTW
            i hope you are not runing a tap:nonono: , you need to use a thread chaser all you are doing is cleaning your threads on the block, you may not see it but taps take a little amount of material off, and thets going to fuck with your torque numbers on your head bolts or studs.
            Francis Njau
            2004 Subaru STI (Stock)
            • MisterCMKM
              MisterCMKM
              eh, its done already. Oh well. Good to know for next time.
              Ford is back :)
              • XJHEADX
                XJHEADX
                Actually what you want to use is a bottoming tap. It does not have the taper to it. The thread sizes are the same. It will let you reach the bottom of the hole.
                Ngige is correct when he said it does affect torque values as you still have material at the bottom of the threads.
                • StangerBanger96S
                  StangerBanger96S
                  StangerBanger96
                  5.0 = Pushrod
                  4.6 = OHC
                  5.0 = Easy to work on and fairly small dimensionally...note the room to work with in his engine bay
                  4.6 = Bitch to work on and picky as hell with mods, also larger than many big block engines.
                  His Engine (5.0)
                  My Engine (4.6)
                  • MisterCMKM
                    MisterCMKM
                    4.6 = simple shit
                    5.0 = awesome shit
                    Ford is back :)
                    • SPANISH-RICES
                      SPANISH-RICES
                      MisterCMK;185753 wrote:
                      4.6 = shit
                      5.0 = shit
                      fixed 😄
                      • StangerBanger96S
                        StangerBanger96S
                        StangerBanger96
                        NA 4.6 = faster than NA Honda
                        NA 5.0 = faster than NA Honda
                        Boosted 4.6 = faster than Boosted Honda
                        Boosted 5.0 = faster than Boosted Honda
                        Double Fixt for you Brandon 😄
                        • MisterCMKM
                          MisterCMKM
                          I got the accessory brackets bolted up and I started gasket matching the intake manifold. I have to go back to Home Depot to buy a different pipe for the damn EGR though. Maybe by this weekend it will run.
                          Ford is back :)
                          • T
                            T
                            thrash
                            Ford engine bays are a complete nightmare. Those pics make me squeamish. I had a 85 Bronco II with the V6 and that thing sucked something fierce.
                            Here's the engine bay of the 1991 BMW M5
                            3.6 liters, 24 valves, 6 throttle butterflies, 310hp, ~270ft/lbs, 7000 rpm, DOHC, shim-over-bucket.
                            • StangerBanger96S
                              StangerBanger96S
                              StangerBanger96
                              You can say that again.
                              • MisterCMKM
                                MisterCMKM
                                Hmm, I haven't had a problem with Ford engine bays. The Expedition with the 5.4 is a little on the tight side, as is the Modular SN95 'Stangs, but other than that they really aren't that bad. I have a 92 Explorer with the 4.0 V6 (basically the same as the truck you had) and there is LOTS of room in there.
                                Ford is back :)
                                • T
                                  T
                                  thrash
                                  The issue is about the rats nest of wires and hoses. Yeah, there's plenty of room in the mustang -- and its all filled with shit.
                                  Look how clean the layout of the M5 engine bay is. Everything is routed logically and cleanly. It's easy to tell what everything is and what it connects to.
                                  • MisterCMKM
                                    MisterCMKM
                                    Meh, its the same way with the Fords too
                                    Ford is back :)
                                    • StangerBanger96S
                                      StangerBanger96S
                                      StangerBanger96
                                      Modular 4.6's and 5.4's are some of the biggest (dimensionally) engines Ford has ever made. They are way too big and way too underpowered.
                                      • MisterCMKM
                                        MisterCMKM
                                        I agree with that. Never said that they weren't.
                                        Ford is back :)
                                        • StangerBanger96S
                                          StangerBanger96S
                                          StangerBanger96
                                          Yeah I'm not sure why I hit the quote button on you there, meant to just say what I said and nothing else.
