  4. missing cam
missing cam
64 Posts 25 Posters 8.9k Views
  • MisterCMKM
    MisterCMKM
    thrash;315544 wrote:
    Ford is back :)
    • MisterCMKM
      MisterCMKM
      And the tap that almost fucked me
      Ford is back :)
      • T
        T
        thrash
        Wow that tap is nasty. How did that happen? Were you using oil?
        Also, what's that a mechanical distributor doing there? I thought I was kidding about 1930 🙂
        • MisterCMKM
          MisterCMKM
          Haha, it is a PIP sensor in there, so its only 1950s tech. 😄
          Anywho, it was just a shitty tap. I wasn't using oil, but it was not getting tough at all and then just snapped. That is what I get for being lazy and not wanting to drive all the way down to Sears to get a good tap. I ended up going down there anyway.
          Ford is back :)
          • XJHEADX
            XJHEADX
            I remember when my engine-bay looked like that.
            • SPANISH-RICES
              SPANISH-RICES
              whatd you do to clean the tops of the pistons while they were still in the motor? worried about anything being between the cylinder and pistons? an earlier pic looked like there was quite a bit of carbon build up
              • MisterCMKM
                MisterCMKM
                Yeah, there was quite a bit of carbon buildup. I used a wire wheel cup that you chuck up in the drill. I brought each piston to the top and cleaned it off and also cleaned off the block. Then, I took brake cleaner and sprayed down the cylinder and rotated the engine until I didn't see any crap left behind in the cylinders. I know that there is going to be some crap left over, but I am going to change my oil right away after I start it up to get some of the stuff cleaned out of there.
                I have both heads on and torqued and the valvetrain re-assembled. Now I have to finish cleaning up the valve covers and then put the intake manifold back on and put 'er back together. I have more pics that I will put up soon.
                Ford is back :)
                • MisterCMKM
                  MisterCMKM
                  Still have polishing left to do on the valve covers.
                  Ford is back :)
                  • T
                    T
                    thrash
                    this is the 4.6 engine right? is it 100% metric hardware now ?
                    • XJHEADX
                      XJHEADX
                      4.6 not until 96'
                      about 1/3 of the 302 shit is metric, pain in the ass
                      • MisterCMKM
                        MisterCMKM
                        The motor is almost all standard but then the body is metric. Fucking clusterfuck. haha
                        Ford is back :)
                        • N
                          N
                          Ngige
                          MisterCMK;185561 wrote:
                          Yup, they have that little pinch in them.
                          I have both heads off and the pistons/block surface cleaned up and ready for the heads. I am working on tapping the block holes and will probably bolt the heads on tonight. Fucking autozone shit taps breaking off blow ass BTW
                          i hope you are not runing a tap:nonono: , you need to use a thread chaser all you are doing is cleaning your threads on the block, you may not see it but taps take a little amount of material off, and thets going to fuck with your torque numbers on your head bolts or studs.
                          Francis Njau
                          2004 Subaru STI (Stock)
                          • MisterCMKM
                            MisterCMKM
                            eh, its done already. Oh well. Good to know for next time.
                            Ford is back :)
                            • XJHEADX
                              XJHEADX
                              Actually what you want to use is a bottoming tap. It does not have the taper to it. The thread sizes are the same. It will let you reach the bottom of the hole.
                              Ngige is correct when he said it does affect torque values as you still have material at the bottom of the threads.
                              • StangerBanger96S
                                StangerBanger96S
                                StangerBanger96
                                5.0 = Pushrod
                                4.6 = OHC
                                5.0 = Easy to work on and fairly small dimensionally...note the room to work with in his engine bay
                                4.6 = Bitch to work on and picky as hell with mods, also larger than many big block engines.
                                His Engine (5.0)
                                My Engine (4.6)
                                • MisterCMKM
                                  MisterCMKM
                                  4.6 = simple shit
                                  5.0 = awesome shit
                                  Ford is back :)
                                  • SPANISH-RICES
                                    SPANISH-RICES
                                    MisterCMK;185753 wrote:
                                    4.6 = shit
                                    5.0 = shit
                                    fixed 😄
                                    • StangerBanger96S
                                      StangerBanger96S
                                      StangerBanger96
                                      NA 4.6 = faster than NA Honda
                                      NA 5.0 = faster than NA Honda
                                      Boosted 4.6 = faster than Boosted Honda
                                      Boosted 5.0 = faster than Boosted Honda
                                      Double Fixt for you Brandon 😄
                                      • MisterCMKM
                                        MisterCMKM
                                        I got the accessory brackets bolted up and I started gasket matching the intake manifold. I have to go back to Home Depot to buy a different pipe for the damn EGR though. Maybe by this weekend it will run.
                                        Ford is back :)
                                        • T
                                          T
                                          thrash
                                          Ford engine bays are a complete nightmare. Those pics make me squeamish. I had a 85 Bronco II with the V6 and that thing sucked something fierce.
                                          Here's the engine bay of the 1991 BMW M5
                                          3.6 liters, 24 valves, 6 throttle butterflies, 310hp, ~270ft/lbs, 7000 rpm, DOHC, shim-over-bucket.
